INCLUDE not working
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Sat Nov 4 09:25:44 EST 2006
Good question. I can tell you that I used includes again a few days ago
on Windows, full paths, 4.10.0, with no problems.
If you think you have found a bug, maybe post a small testcase (mapfile
and data) to the original include bug
(http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=279).
jeff
Eric Shuman wrote:
> I am trying to update a functioning map file to use the INCLUDE directive
> for all of my layer definitions. I have used one of my LAYER directives as a
> new map file and inserted an INCLUDE in my current map file.
> INCLUDE "/full-path-to-file/newfile.map"
> I get this error
> Warning: [MapServer Error]: msLoadMap(): Parsing error near
> (INCLUDE):(line 133) in ....
> I have upgraded my mapserver version to 4.10.0. See below for my full
> version info. The Layer directive and the map file work without the INCLUDE.
> What am I missing??
> ~Eric
> MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> * FGS API version : 0.2
> * NAME VERSION
> * apache-base 1.3.34
> * curl-lib 7.15.0
> * expat-base 1.95.8
> * freetype-lib 2.1.9
> * gdal-base 1.3.2
> * gd-lib 2.0.33
> * geos-lib 2.1.3
> * jpeg-lib 6b
> * libgeotiff-lib 1.2.2
> * libiconv-base 1.9.1
> * libpng-lib 1.2.8
> * libungif-base 4.1.3
> * mapserver-base 4.10.0
> * mapserver-php 4.6.2
> * netcdf-lib 3.5.1
> * openssl-lib 0.9.8b
> * pdflib_lite-base 5.0.4p1
> * php-base 4.3.11
> * php_pdf-module 4.3.11
> * php_pgsql-module 4.3.11
> * postgis-lib 1.0.4
> * postgresql-lib 8.0.7
> * postgresql-server 8.0.4
> * proj4_epsg42xxx-support 1.0.0
> * proj-lib 4.4.8
> * tiff-lib 3.7.2
> * unixODBC-base 2.2.10
> * xerces_c-base 2_6_0
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
