php mapscript error
Aaron Racicot
aaronr at Z-PULLEY.COM
Fri Nov 3 17:12:33 EST 2006
You need INPUT=OGR to have access to vector functions in GDAL/OGR via
Mapserver. It looks like you only have GDAL enabled. Look at the
--with-ogr switch when building Mapserver.
A
| Aaron Racicot | aaronr at ecotrust.org |
| GIS Programmer | 360.221.2441 |
| e c o t r u s t |
| Jean Vollum Natural Capital Center |
| 721 NW Ninth Avenue |
| Suite 200 |
| Portland, OR 97209 |
| www.ecotrust.org |
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Kipp Jones
Sent: Friday, November 03, 2006 1:56 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] php mapscript error
This may be a configuration error, but I'm stumped. I'm getting an error
when trying to use ogr to connect to mysql via phpmapscript. The error:
PHP Warning: [MapServer Error]: msOGRLayerOpen(): OGR support is not
available.
I'm running on Mac OS X 10.4.8.
Things seem to be happy, gmap is working just fine.
My output from phpinfo shows:
MapServer Version
MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=THREADS INPUT=EPPL7 INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
PHP MapScript Version
($Revision: 1.260 $ $Date: 2006/09/06 16:42:36 $)
The layer in my map is pretty simple:
LAYER
NAME "scanner"
STATUS DEFAULT
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "/Users/kippster/tiger/scanner.ovf"
DATA "scanner"
CLASS
NAME "scanner"
STYLE
SYMBOL 2
SIZE 15
COLOR 0 255 0
END
END
END
My ovf file is:
<OGRVRTDataSource>
<OGRVRTLayer name="scanner">
<SrcDataSource>MYSQL:db,user=xxxx,password=xxxxxx,host=127.0.0.1,port=3306,t
ables=GpsLogs</SrcDataSource>
<SrcSQL>SELECT scannerId, latitude, longitude FROM GpsLogs</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="latitude"
y="longitude"/>
</OGRVRTLayer>
</OGRVRTDataSource>
When I perform ' ogrinfo /Users/kippster/tiger/scanner.ovf -al' it spews out
all of the data points in the db just fine.
Any ideas?
Thanks!
Kipp
