php mapscript error
Kipp Jones
kippster at YAHOO.COM
Fri Nov 3 13:55:47 PST 2006
This may be a configuration error, but I'm stumped. I'm getting an
error when trying to use ogr to connect to mysql via phpmapscript.
The error:
PHP Warning: [MapServer Error]: msOGRLayerOpen(): OGR support is not
available.
I'm running on Mac OS X 10.4.8.
Things seem to be happy, gmap is working just fine.
My output from phpinfo shows:
MapServer Version
MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=THREADS INPUT=EPPL7 INPUT=GDAL
INPUT=SHAPEFILE DEBUG=MSDEBUG
PHP MapScript Version
($Revision: 1.260 $ $Date: 2006/09/06 16:42:36 $)
The layer in my map is pretty simple:
LAYER
NAME "scanner"
STATUS DEFAULT
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "/Users/kippster/tiger/scanner.ovf"
DATA "scanner"
CLASS
NAME "scanner"
STYLE
SYMBOL 2
SIZE 15
COLOR 0 255 0
END
END
END
My ovf file is:
<OGRVRTDataSource>
<OGRVRTLayer name="scanner">
<SrcDataSource>MYSQL:db,user=xxxx,password=xxxxxx,host=127.0.0.1,port=33
06,tables=GpsLogs</SrcDataSource>
<SrcSQL>SELECT scannerId, latitude, longitude FROM GpsLogs</
SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="latitude"
y="longitude"/>
</OGRVRTLayer>
</OGRVRTDataSource>
When I perform ' ogrinfo /Users/kippster/tiger/scanner.ovf -al' it
spews out all of the data points in the db just fine.
Any ideas?
Thanks!
Kipp
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061103/1843df53/attachment.htm>
More information about the MapServer-users
