php mapscript error
Kipp Jones
kippster at YAHOO.COM
Fri Nov 3 18:27:08 EST 2006
Thanks William & Aaron...great to have such quick response.
I did end up building it on my own -- and boy was that fun :-) I was
following the information (thanks btw!) on http://www.kyngchaos.com/
macosx/install/mapserv -- but grabbed the 4.10.0 version instead of
the 4.6.0 version...
Here is the configure comman I used:
./configure --mandir=/usr/local/share/man --with-proj=/usr/local --
with-gdal=/usr/local/bin/gdal-config --with-ogr=/usr/local/bin/gdal-
config --with-gd=/usr/local --with-xpm=/usr/X11R6 --with-php=/usr/
local --with-geos=/usr/local/bin/geos-config --with-wfs --with-wcs --
with-wfsclient --with-wmsclient --with-freetype=/usr/:qX11R6/bin/
freetype-config
I swear I tried to use a package install earlier on in the process,
but perhaps I should drop back and try that again...
Thanks again,
Kipp
On Nov 3, 2006, at 5:43 PM, William Kyngesburye wrote:
> Did you build MapServer and GDAL yourself? A Aaron pointed out,
> you might have missed the --with-ogr option in mapserver, it's not
> automatic when you enable gdal support.
> Alternatively, have you looked at my MapServer package for OSX? If
> there is something missing that you need, let me know.
> On Nov 3, 2006, at 3:55 PM, Kipp Jones wrote:
>> This may be a configuration error, but I'm stumped. I'm getting
>> an error when trying to use ogr to connect to mysql via
>> phpmapscript. The error:
>> PHP Warning: [MapServer Error]: msOGRLayerOpen(): OGR support is
>> not available.
>> I'm running on Mac OS X 10.4.8.
>> Things seem to be happy, gmap is working just fine.
>> My output from phpinfo shows:
>> MapServer Version
>> MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
>> SUPPORTS=WMS_SERVER SUPPORTS=THREADS INPUT=EPPL7 INPUT=GDAL
>> INPUT=SHAPEFILE DEBUG=MSDEBUG
>> PHP MapScript Version
>> ($Revision: 1.260 $ $Date: 2006/09/06 16:42:36 $)
> William Kyngesburye <kyngchaos at kyngchaos.com>
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
