Compiling mapscript-csharp on Linux
Mike Leahy
mgleahy at GOLDEN.NET
Sun Nov 5 01:35:29 EST 2006
Hello list,
I just finished compiling MapServer on FC6, and I was wondering about
some errors I had when I compiled the C# mapscript library. There is a
line related to the MySQL support in the csharp Makefile that looks like so:
MYGIS_INC= -I/usr/include/mysql -g -pipe -Wp,-D_FORTIFY_SOURCE=2
-fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64
-mtune=generic -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE
-fno-strict-aliasing -fwrapv
If I leave it as-is, I get the following errors when I attempt to
compile the module with make:
swig error : Unrecognized option -g
swig error : Unrecognized option -pipe
swig error : Unrecognized option -Wp,-D_FORTIFY_SOURCE=2
swig error : Unrecognized option -fexceptions
swig error : Unrecognized option -fstack-protector
swig error : Unrecognized option --param=ssp-buffer-size=4
swig error : Unrecognized option -m64
swig error : Unrecognized option -mtune=generic
swig error : Unrecognized option -fno-strict-aliasing
swig error : Unrecognized option -fwrapv
Use 'swig -help' for available options.
make: *** [interface] Error 1
So...I removed everthing on that line starting with '-g', and it
compiled fine. My question is whether this is something that I'm likely
to run into trouble with later on - I don't generally use MySQL, so my
guess is no. If anyone has any insight related to this, I'd be
interested to hear it.
Thanks,
Mike
