Compiling mapscript-csharp on Linux
Mike Leahy
mgleahy at GOLDEN.NET
Mon Nov 6 18:20:48 EST 2006
Hello again,
It looks like I am having problems with the mapscript_csharp library.
Earlier, I had neglected to run 'make test', and now that I do, I find
I'm getting an Unhandled Exception (see below). It seems that it is the
libmapscript.so that has this problem, since if I use the
mapscript_csharp.dll in windows with a pre-compiled copy of
mapscript.dll, it works fine as far as I can tell. Once I try to do the
same in Linux with the libmapscript.so that I compiled, it fails with
the same errors as the make test output. I'm not sure why I would get a
System.DllNotFoundException - I tried copying the library to my lib
folder. If it try 'ldd libmapscript.so', the output also looks okay.
I might also point out that I had a number of funny error messages about
incompatible libraries at the end of the compile process, when the
php_mapscript.so library is created. These messages look something like
"/usr/bin/ld: skipping incompatible /usr/lib/lxml2.so when searching for
-lxml2", and the list is pretty long. So far, it seems the library
loads fine in PHP, though I haven't had a chance to test it with an
actual map yet. Could the fact that I'm running on an x86_64 version of
Fedora 6 be a problem?
I hope somebody on the list can give me some insight into this problem.
Mike
============ output from 'make test' in mapscript/csharp ==========
mgleahy at localhost csharp]$ make test
LC_ALL=C mono ./shpdump.exe ../../tests/point.shp
Unhandled Exception: System.TypeInitializationException: An exception
was thrown by the type initializer for mapscriptPINVOKE --->
System.TypeInitializationException: An exception was thrown by the type
initializer for SWIGExceptionHelper ---> System.DllNotFoundException:
libmapscript.so
at (wrapper managed-to-native)
SWIGExceptionHelper:SWIGRegisterExceptionCallbacks_mapscript
(mapscriptPINVOKE/SWIGExceptionHelper/ExceptionDelegate,mapscriptPINVOKE/SWIGExceptionHelper/ExceptionDelegate,mapscriptPINVOKE/SWIGExceptionHelper/ExceptionDelegate,mapscriptPINVOKE/SWIGExceptionHelper/ExceptionDelegate,mapscriptPINVOKE/SWIGExceptionHelper/ExceptionDelegate,mapscriptPINVOKE/SWIGExceptionHelper/ExceptionDelegate,mapscriptPINVOKE/SWIGExceptionHelper/ExceptionDelegate,mapscriptPINVOKE/SWIGExceptionHelper/ExceptionDelegate,mapscriptPINVOKE/SWIGExceptionHelper/ExceptionDelegate,mapscriptPINVOKE/SWIGExceptionHelper/ExceptionDelegate)
at mapscriptPINVOKE+SWIGExceptionHelper..cctor () [0x00000] --- End
of inner exception stack trace ---
at <0x00000> <unknown method>
at mapscriptPINVOKE..cctor () [0x00000] --- End of inner exception
stack trace ---
at shapefileObj..ctor (System.String filename, Int32 type) [0x00000]
at ShapeDump.Main (System.String[] args) [0x00000]
make: *** [test] Error 1
Mike Leahy wrote:
> Hello list,
> I just finished compiling MapServer on FC6, and I was wondering about
> some errors I had when I compiled the C# mapscript library. There is a
> line related to the MySQL support in the csharp Makefile that looks like
> so:
> MYGIS_INC= -I/usr/include/mysql -g -pipe -Wp,-D_FORTIFY_SOURCE=2
> -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64
> -mtune=generic -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE
> -fno-strict-aliasing -fwrapv
> If I leave it as-is, I get the following errors when I attempt to
> compile the module with make:
> swig error : Unrecognized option -g
> swig error : Unrecognized option -pipe
> swig error : Unrecognized option -Wp,-D_FORTIFY_SOURCE=2
> swig error : Unrecognized option -fexceptions
> swig error : Unrecognized option -fstack-protector
> swig error : Unrecognized option --param=ssp-buffer-size=4
> swig error : Unrecognized option -m64
> swig error : Unrecognized option -mtune=generic
> swig error : Unrecognized option -fno-strict-aliasing
> swig error : Unrecognized option -fwrapv
> Use 'swig -help' for available options.
> make: *** [interface] Error 1
> So...I removed everthing on that line starting with '-g', and it
> compiled fine. My question is whether this is something that I'm likely
> to run into trouble with later on - I don't generally use MySQL, so my
> guess is no. If anyone has any insight related to this, I'd be
> interested to hear it.
> Thanks,
> Mike
