no output for web template with 4.10 cgi
piero cavalieri
piero.cavalieri at HEIDI.IT
Mon Nov 6 08:52:54 EST 2006
I found I have a problem with some layers. One of this is:
LAYER
NAME laghi
DEBUG on
METADATA
"wms_title" "laghi"
"DESCRIPTION" "Laghi"
"RESULT_FIELDS" "ASTA DES INDIVIDUAZ"
END
PROJECTION
"init=epsg:26591"
END
TYPE polygon
STATUS ON
DATA idrlag
LABELITEM "des"
LABELMAXSCALE 30000
CLASS
NAME "Laghi"
COLOR 0 0 250
TEMPLATE "templates/laghi.xml"
LABEL
POSITION CC
SIZE MEDIUM
COLOR 0 0 250
OUTLINECOLOR 220 220 220
END
END
#TRANSPARENCY 50
TOLERANCE 5
HEADER "templates/layer_header.xml"
FOOTER "templates/layer_footer.xml"
END
(I think templates/laghi.xml is ininfluent here because the layer
crashes in browse mode). Do you see something strange ?
Also on 3 other layers, I have images in temp dir are built correctly,
but in the html they are not refreshed, i.e.:
I do a zoom with the trouble layer present, the images are build (all
images: map, scalebar, html legend icons, reference), but then html
interface is not updated with the new images. I did never had this kind
of problems with previous mapserver releses (but maybe this time I did
something wrong in setting up cgi...)
Piero
J. Parapar ha scritto:
> Hi Piero.
> We are also having problems with HTML templates using MapServer 4.10
> (http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1946). It works
> well using MapServer 4.8.4 so it seems there has been some changes in
> version 4.10 which have affected to the HTML templates but we do not
> know what. But it is rare that there are not more people affected by
> this so perhaps we are doing something wrong.
> Best regards,
> Jorge
> 2006/11/3, piero cavalieri <piero.cavalieri at heidi.it>:
>> Hi all,
>> I use cgi 4.10 (tried both from DMSolutions and TWtools) and do a
>> request like this:
>> http://localhost/Scripts/mapserv.exe?map=D:/Web/Site/HGis/trentino.map&layer=DTM&layer=ECW&mode=browse
>> My web template file is an xml file:
>> <?xml version="1.0" encoding="utf-8" ?>
>> <map>
>> <img value="[img]"/>
>> <mapwidth value="[mapwidth]"/>
>> <mapheight value="[mapheight]"/>
>> <scalebar value="[scalebar]"/>
>> <referenceMap value="[ref]"/>
>> <imgxy value="[center]"/>
>> <imgext value="[mapext]"/>
>> <legend>
>> <![CDATA[
>> [legend]
>> </legend>
>> </map>
>> With 4.6 cgi this worked fine.
>> Then I had to format/reinstall my WindowsXp and tried 4.10, but with the
>> same web application I have the following cgi output:
>> msDrawMap(): Layer 5 (laghi), 0.079s msDrawMap(): Layer 11 (i_dep_p),
>> 0.078s
>> instead of the xml file from web template. In temp dir I have all the
>> images created for the request (map, scalebar ecc.), so cgi
>> installation
>> seems to be ok.
>> I don't try using the old 4.6 (because I don't have it any more). Anyone
>> could give an advice please ?
>> Thanks
>> Piero
