no output for web template with 4.10 cgi
J. Parapar
listario at GMAIL.COM
Mon Nov 6 10:06:20 EST 2006
Hi Piero
Sorry, I misunderstood your first mail. At first glance I do not see
anything strange. You can try to isolate the problem by using
different modes (map, legend, scalebar, ...) and simplifying the layer
defintion. Sorry I can not help much.
Best regards,
Jorge
2006/11/6, piero cavalieri <piero.cavalieri at heidi.it>:
> I found I have a problem with some layers. One of this is:
> LAYER
> NAME laghi
> DEBUG on
> METADATA
> "wms_title" "laghi"
> "DESCRIPTION" "Laghi"
> "RESULT_FIELDS" "ASTA DES INDIVIDUAZ"
> END
> PROJECTION
> "init=epsg:26591"
> END
> TYPE polygon
> STATUS ON
> DATA idrlag
> LABELITEM "des"
> LABELMAXSCALE 30000
> CLASS
> NAME "Laghi"
> COLOR 0 0 250
> TEMPLATE "templates/laghi.xml"
> LABEL
> POSITION CC
> SIZE MEDIUM
> COLOR 0 0 250
> OUTLINECOLOR 220 220 220
> END
> END
> #TRANSPARENCY 50
> TOLERANCE 5
> HEADER "templates/layer_header.xml"
> FOOTER "templates/layer_footer.xml"
> END
> (I think templates/laghi.xml is ininfluent here because the layer
> crashes in browse mode). Do you see something strange ?
> Also on 3 other layers, I have images in temp dir are built correctly,
> but in the html they are not refreshed, i.e.:
> I do a zoom with the trouble layer present, the images are build (all
> images: map, scalebar, html legend icons, reference), but then html
> interface is not updated with the new images. I did never had this kind
> of problems with previous mapserver releses (but maybe this time I did
> something wrong in setting up cgi...)
> Piero
> J. Parapar ha scritto:
> > Hi Piero.
> > We are also having problems with HTML templates using MapServer 4.10
> > (http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1946). It works
> > well using MapServer 4.8.4 so it seems there has been some changes in
> > version 4.10 which have affected to the HTML templates but we do not
> > know what. But it is rare that there are not more people affected by
> > this so perhaps we are doing something wrong.
> > Best regards,
> > Jorge
> > 2006/11/3, piero cavalieri <piero.cavalieri at heidi.it>:
> >> Hi all,
> >> I use cgi 4.10 (tried both from DMSolutions and TWtools) and do a
> >> request like this:
> >> http://localhost/Scripts/mapserv.exe?map=D:/Web/Site/HGis/trentino.map&layer=DTM&layer=ECW&mode=browse
> >> My web template file is an xml file:
> >> <?xml version="1.0" encoding="utf-8" ?>
> >> <map>
> >> <img value="[img]"/>
> >> <mapwidth value="[mapwidth]"/>
> >> <mapheight value="[mapheight]"/>
> >> <scalebar value="[scalebar]"/>
> >> <referenceMap value="[ref]"/>
> >> <imgxy value="[center]"/>
> >> <imgext value="[mapext]"/>
> >> <legend>
> >> <![CDATA[
> >> [legend]
> >> </legend>
> >> </map>
> >> With 4.6 cgi this worked fine.
> >> Then I had to format/reinstall my WindowsXp and tried 4.10, but with the
> >> same web application I have the following cgi output:
> >> msDrawMap(): Layer 5 (laghi), 0.079s msDrawMap(): Layer 11 (i_dep_p),
> >> 0.078s
> >> instead of the xml file from web template. In temp dir I have all the
> >> images created for the request (map, scalebar ecc.), so cgi
> >> installation
> >> seems to be ok.
> >> I don't try using the old 4.6 (because I don't have it any more). Anyone
> >> could give an advice please ?
> >> Thanks
> >> Piero
