FW: Info on MapServer
P Kishor
punkish at EIDESIS.ORG
Mon Nov 6 10:13:58 EST 2006
Good golly... this should be converted into a FAQ, or, into a "What
you need to know about MapServer before you begin."
Very well explained answers Frank.
On 11/6/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Raj writes:
> > 1. Is this a complete web based engine where we could offer a web
> > based solution on the same with around 200-300 users accessing the
> > application simultaneously for map viewing.
> Raj,
> MapServer will support 200-300 users with an appropriately configured
> application, though I'd consider that a high load for a single machine
> serving maps and you would likely need to be quite careful about how
> your application is setup.
> I'm not sure what you mean by a "complete web based engine". MapServer
> is not a GIS and does not endevour to have a complete set of GIS
> functionality. You may also find you need a variety of related projects
> to achieve some ends. In particular there are many layered software
> packages that can be used with mapserver to make building web applications
> easier. Packages such as CartoWeb, Chameleon, Mapbender, MapBuilder,
> and ka-Map (as a few examples). You will want to review some of these
> higher level packages as part of your review of mapserver.
> > 2. Do you have any benchmarks on the map rendering speed on the web
> > with the above load? If so kindly furnish us the same.
> I do not, perhaps others do. Generally speaking you are best off
> doing some benchmarking yourself, and understanding that performance can
> be very sensitive to a variety of issues (data organization, machine
> memory, etc).
> > 3. Does the map engine support the following features.
> > 1. Map navigating tools zoom in, zoom out, distance, info
> > tool, auto pan, centering
> yes
> > 2. Does it support both vector and rastor map data set?
> yes
> > 3. Does it support MS-SQL and Oracle as backend database for
> > the attributes?
> Yes, though the normal MapServer model is for the attributes to be
> conceptually stored with the spatial geometry. Trying to do joins on the
> fly can be problematic, especially in performance sensitive situations.
> Note that there is good Oracle Spatial support built in. Access to
> MS-SQL is via the OGR ODBC driver and can be considered weaker.
> > 4. Does it support animation layer? i.e. creating point objects
> > on the fly over web ?for eg. Vehicle tracking.
> I believe you would need to use a client side toolkit such as MapBuilder
> to have AJAX style client side animation. Or perhaps you just mean
> rendering from dynamic datasets? This is quite possible.
> > 5. Does it support radial distance / search?
> yes
> > 6. Does it support buffering for line and point objects?
> yes, though this is a new feature, I think accessible only in mapscript.
> > 7. Does it support editing the layers on the web – like
> > creating points, drawing lines etc.
> Generally speaking no, MapServer does not support feature editing well.
> There are some environments (Mapbender?) that address this sort of need,
> but I think they post changes back to transactional WFS'es like GeoServer.
> Use of GeoServer as a WFS and MapServer as a WMS is a fairly common
> configuration for such requirements.
> > 8. Does it have a distance calculator?
> I am not aware of one built in, though environments like Chameleon may
> include this.
> > 9. Which is map data format supported? Does it support both
> > shape files (ESRI), MapInfo format as well Oracle spatial or
> > any other geo-database format.
> The "native" format is shapefiles (in the sense this is the original and
> in many ways best optimized format), but Oracle Spatial is also well
> supported. Via OGR a variety of formats are supported including mapinfo
> (mid/mif and tab), etc.
> http://www.gdal.org/ogr/
> > 4. Does the map server have a licensing cost and does it have any
> > restrictions with respect to number of simultaneous users?
> No, sorry. We are missing this feature.
> > 5. What is the level of support and documentation provided for a
> > serious user like us?
> I'd suggest you visit the mapserver website to judge the available
> documentation. If you want support you can call on the mapserver
> mailing lists but for serious support you may consider contracting
> with experienced mapserver consultants including firms like DM Solutions,
> or MapGears, and individuals such as Steve Lime, or Howard Butler.
> I personally think that MapServer and related projects is a great solution
> for consultants and integrators willing to spend some time learning MapServer
> and who have the experience and knowledge to customize and extend things
> when required. This gives great flexibility in providing exactly the solution
> a client needs, and ensures you aren't trapped into the licensing/pricing
> scheme of a vendor who may be insensitive to your needs or the needs of
> some of your clients.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
Puneet Kishor http://punkish.eidesis.org/
Nelson Inst. for Env. Studies, UW-Madison http://www.nelson.wisc.edu/
Open Source Geospatial Foundation https://edu.osgeo.org/
collaborate, communicate, compete
