no output for web template with 4.10 cgi
piero cavalieri
piero.cavalieri at HEIDI.IT
Tue Nov 7 05:52:39 EST 2006
I think it's not a layer problem, because this map file was used also 2
years ago with gmap demo application (that from dmsolutions, with php
and the java applet), then with a .net (pure post) and then with
.net/ajax, and never had this problem. Tested on a WinXp and
Win2003Server and was ok.
I think I'll try to take exatly the same configuration I still have on
the Win2003 (which uses 4.6), and then replace with 4.10. If I'll still
have the problem, I'll try to isolate it.
Thanks
P.
Steve Lime ha scritto:
> I'm not using an HTML legend in this case. Seems like a layer problem
> as you noted in follow-up messages.
> Steve
>>>> Steve Lime <Steve.Lime at DNR.STATE.MN.US> 11/6/2006 1:02:57 PM >>>
> Checking into this...
> Steve
>>>> piero cavalieri <piero.cavalieri at HEIDI.IT> 11/3/2006 11:28:57 AM
> Hi all,
> I use cgi 4.10 (tried both from DMSolutions and TWtools) and do a
> request like this:
> http://localhost/Scripts/mapserv.exe?map=D:/Web/Site/HGis/trentino.map&layer=DTM&layer=ECW&mode=browse
> My web template file is an xml file:
> <?xml version="1.0" encoding="utf-8" ?>
> <map>
> <img value="[img]"/>
> <mapwidth value="[mapwidth]"/>
> <mapheight value="[mapheight]"/>
> <scalebar value="[scalebar]"/>
> <referenceMap value="[ref]"/>
> <imgxy value="[center]"/>
> <imgext value="[mapext]"/>
> <legend>
> <![CDATA[
> [legend]
> </legend>
> </map>
> With 4.6 cgi this worked fine.
> Then I had to format/reinstall my WindowsXp and tried 4.10, but with
> the
> same web application I have the following cgi output:
> msDrawMap(): Layer 5 (laghi), 0.079s msDrawMap(): Layer 11 (i_dep_p),
> 0.078s
> instead of the xml file from web template. In temp dir I have all the
> images created for the request (map, scalebar ecc.), so cgi
> installation
> seems to be ok.
> I don't try using the old 4.6 (because I don't have it any more).
> Anyone
> could give an advice please ?
> Thanks
> Piero
