no output for web template with 4.10 cgi
piero cavalieri piero.cavalieri at HEIDI.IT
Tue Nov 7 03:30:12 PST 2006
And, I repeat, I have the images (also with the problematic layers)
correctly saved in the temp dir. Simply the xml output have additional
(mapserver logs ??) lines, sometimes at the beginning, sometimes at the
end of the output stream (so an exception thorws during the xml parsing,
which is after mapserver produced the jpegs; if I would like to make a
dirty patch in this moment, I could simply remove the log lines form the
output template before doing the xml parse).
A question: msDrawMap(): Layer 8 (sma_cob), 0.000s  means really that
mapsrver take less than 0.001s to render  the layer or has to be
interpreted as an error message?
P.
piero cavalieri ha scritto:
> Yes, your output is clean. However also for me the output is clean,
> with some layers. For other  it's not. I have additional  lines like
> msDrawMap(): Layer 9 (sma_con), 0.000s
> at the end of the file. So I'll try to isolate the prblem (when I'll
> have a bit of time).
> Thanks
>    P.
> Steve Lime ha scritto:
>> I can confirm the template works ok, see:
>> http://maps.dnr.state.mn.us/cgi-bin/mapserv410?map=/usr/local/www/docs_maps/mapserver_demos/itasca/test.map
>> I'm not using an HTML legend in this case. Seems like a layer problem
>> as you noted in follow-up messages.
>> Steve
>>>>> Steve Lime <Steve.Lime at DNR.STATE.MN.US> 11/6/2006 1:02:57 PM >>>
>> Checking into this...
>> Steve
>>>>> piero cavalieri <piero.cavalieri at HEIDI.IT> 11/3/2006 11:28:57 AM
>> Hi all,
>> I use cgi 4.10 (tried both from DMSolutions and TWtools)  and do a
>> request like this:
>> http://localhost/Scripts/mapserv.exe?map=D:/Web/Site/HGis/trentino.map&layer=DTM&layer=ECW&mode=browse
>> My web template file is an xml file:
>> <?xml version="1.0" encoding="utf-8" ?>
>> <map>
>>  <img value="[img]"/>
>>  <mapwidth value="[mapwidth]"/>
>>  <mapheight value="[mapheight]"/>
>>  <scalebar value="[scalebar]"/>
>>  <referenceMap value="[ref]"/>
>>  <imgxy value="[center]"/>
>>  <imgext value="[mapext]"/>
>>  <legend>
>>      <![CDATA[
>>      [legend]
>>  </legend>
>> </map>
>> With 4.6 cgi this worked fine.
>> Then I had to format/reinstall my WindowsXp and tried 4.10, but with
>> the same web application I have the following cgi output:
>> msDrawMap(): Layer 5 (laghi), 0.079s msDrawMap(): Layer 11 (i_dep_p),
>> 0.078s
>> instead of the xml file from web template.  In temp dir I have all the
>> images created for the  request (map, scalebar ecc.), so cgi
>> installation
>> seems to be ok.
>> I don't try using the old 4.6 (because I don't have it any more).
>> Anyone could give an advice please ?
>> Thanks
>>     Piero
More information about the MapServer-users mailing list
