itemquery by cgi mapserver (2nd-p)
karpi
karpi.lists at EMAIL.CZ
Tue Nov 7 10:02:19 EST 2006
Hello..
There is one mapserver application, which im some time ago working on:
http://localhost/cgi-bin/mapserv?map=/var/www/localhost/htdocs/newmap/czrep.map
(MapServer version 4.8.3)
If user enters a search string "Praha"
result is ok, but unfortunatelly:
- Serarching works only if entered qstring is exactly identical with database
item (which is "Praha"). No case insensitiving. So -> qstring "praha" fails.
- Searching fails on substrings, so searching "aha" fails on "Praha",
and searching "Kralupy" fails on "Kralupy nad Vltavou"
- Searching is limited on displayed map extents. If im zoomed out, even
correct string "Praha" fails
Do you solved someone some of this points before? Any expiriences?
(second post - the first one disappeard somewere..)
karpi from
http://gismaster.liberix.cz
