itemquery by cgi mapserver (2nd-p)
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Nov 7 10:25:52 EST 2006
What you describe is how things are supposed to work. There are
alternatives:
- case insensitivity, by default string and regular expressions are
case insensitive. You can get around that by including an i at the end
of the qstring. For a case-insensitive string search you'd need to
delimit the string with quotes and then append the i.
qstring=/Praha/i
qstring='Praha'i
- substrings, you need to use regular expressions to do substring
matches
- limited by extents, again this is the default behaviour. You often
deal with it through application design. For example, if you have your
search by keyword form element inside the main mapserver form then it
will take on the displayed extent. Alternatively you could use a
seperate form altogether. You can also use a bit of javascript to
construct a query URL with the correct global extent and then submit.
You'll probably need to do that anyway to format your qstring
appropriately. Remember that if no extent is supplied then the search
uses the default extent set in the mapfile.
Steve
>>> karpi <karpi.lists at EMAIL.CZ> 11/07/06 9:02 AM >>>
Hello..
There is one mapserver application, which im some time ago working on:
http://localhost/cgi-bin/mapserv?map=/var/www/localhost/htdocs/newmap/czrep.map
(MapServer version 4.8.3)
If user enters a search string "Praha"
result is ok, but unfortunatelly:
- Serarching works only if entered qstring is exactly identical with
database
item (which is "Praha"). No case insensitiving. So -> qstring "praha"
fails.
- Searching fails on substrings, so searching "aha" fails on "Praha",
and searching "Kralupy" fails on "Kralupy nad Vltavou"
- Searching is limited on displayed map extents. If im zoomed out, even
correct string "Praha" fails
Do you solved someone some of this points before? Any expiriences?
(second post - the first one disappeard somewere..)
karpi from
http://gismaster.liberix.cz
