no output for web template with 4.10 cgi; solved
piero cavalieri
piero.cavalieri at HEIDI.IT
Tue Nov 7 13:11:57 EST 2006
Daniel Morissette ha scritto:
> piero cavalieri wrote:
>> And, I repeat, I have the images (also with the problematic layers)
>> correctly saved in the temp dir. Simply the xml output have
>> additional (mapserver logs ??) lines, sometimes at the beginning,
>> sometimes at the end of the output stream (so an exception thorws
>> during the xml parsing, which is after mapserver produced the jpegs;
>> if I would like to make a dirty patch in this moment, I could simply
>> remove the log lines form the output template before doing the xml
>> parse).
> There is a known issue with IIS, DEBUG messages end up mixed with the
> regular mapserv.exe output:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1783
> The way around this is to disable the DEBUG statements in your mapfile.
That solved! Thank you!
> Another alternative is to use Apache which doesn't suffer from this
> problem even on Windows.
Do you think I tell my boss to change WebServer for an application bug
? I want to stay alive... ;-)
>> A question: msDrawMap(): Layer 8 (sma_cob), 0.000s means really that
>> mapsrver take less than 0.001s to render the layer or has to be
>> interpreted as an error message?
> That's correct, that means that less than 0.001s is septn rendering
> that layer, either because it's a very light layer or because it is
> out of scale.
In fact I realized just after sending the post, that the layer was out
of scale .... ;-)
> Daniel
Thank u
Piero
