ovf query error
Pagurek,Debbie [NCR]
Debbie.Pagurek at EC.GC.CA
Tue Nov 7 17:09:30 EST 2006
in your mapfile, make sure you have DUMP TRUE (you can put this
somewhere in your layer)
Hope that works,
D. Pagurek
_____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of william paul
Sent: Tuesday, November 07, 2006 2:34 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] ovf query error
Hi:
I have created a OVF file to generate point files from MS SqlServer and
it's working OK. I can see the point but When I try to query I get:
msQueryByPoint() Search returned no results. No matching record(s) found
In the ovf file I have:
<FID>UID</FID>
In Map file:
class
template.html
end
header header_template.html
footer footer_template.html
in template I have:
<tr>.....<td>[UID]</td>
The table in the SQL Server I have 3 columns:
UID type uniqueidentifier
x_coord type float
y_coord type float
I don't see where I do wrong
Thank you in advance
William
_____
Sponsored Link
Talk more and pay less. Vonage can save you up to $300 a year on your
phone bill. Sign up now.
<http://clk.atdmt.com/VON/go/yhxxxvon1080000017von/direct/01/>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061107/0d59d5c3/attachment.html
