ovf query error
william paul
williampaul28 at YAHOO.COM
Tue Nov 7 17:28:06 EST 2006
Thank you, but it didn't solved the problem. I have created in the SQL Server a column called FID. With this column and removing the <FID>...</FID> line from the ovf file I can make query, but when I click on different point I get the same result: the first tupple from Sql Server table. For each point I query I get only the records for the first point.
Any ideas? or whe I can setup <FID>mycolumnid</FID>?
William
"Pagurek,Debbie [NCR]" <Debbie.Pagurek at EC.GC.CA> wrote: in your mapfile, make sure you have DUMP TRUE (you can put this somewhere in your layer)
Hope that works,
D. Pagurek
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of william paul
Sent: Tuesday, November 07, 2006 2:34 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] ovf query error
Hi:
I have created a OVF file to generate point files from MS SqlServer and it's working OK. I can see the point but When I try to query I get: msQueryByPoint() Search returned no results. No matching record(s) found
In the ovf file I have:
<FID>UID</FID>
In Map file:
class
template.html
end
header header_template.html
footer footer_template.html
in template I have:
<tr>.....<td>[UID]</td>
The table in the SQL Server I have 3 columns:
UID type uniqueidentifier
x_coord type float
y_coord type float
I don't see where I do wrong
Thank you in advance
William
Sponsored Link
Talk more and pay less. Vonage can save you up to $300 a year on your phone bill. Sign up now.
Sponsored Link
Free Uniden 5.8GHz Phone System with Packet8 Internet Phone Service
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061107/a9da6099/attachment.html
