ovf query error
Pagurek,Debbie [NCR]
Debbie.Pagurek at EC.GC.CA
Wed Nov 8 09:28:38 EST 2006
Hmm - interesting. The symptom that you discuss here - the fact that
without the FID specified you only get the first record - indicated that
you need to specify a FID in your OVF file. What version on SQL Server
are you using? And, is your FID column defined in SQL server as the
primary key on the table? By the way - I use SQL Server 2000 and I do
not have to specify FID in my OVF to get my queries working.
Anyone else have any suggestions??
D. Pagurek
_____
From: william paul [mailto:williampaul28 at yahoo.com]
Sent: Tuesday, November 07, 2006 5:28 PM
To: Pagurek,Debbie [NCR]; mapserver mapserver
Subject: Re: [UMN_MAPSERVER-USERS] ovf query error
Thank you, but it didn't solved the problem. I have created in the SQL
Server a column called FID. With this column and removing the
<FID>...</FID> line from the ovf file I can make query, but when I click
on different point I get the same result: the first tupple from Sql
Server table. For each point I query I get only the records for the
first point.
Any ideas? or whe I can setup <FID>mycolumnid</FID>?
William
"Pagurek,Debbie [NCR]" <Debbie.Pagurek at EC.GC.CA> wrote:
in your mapfile, make sure you have DUMP TRUE (you can put this
somewhere in your layer)
Hope that works,
D. Pagurek
_____
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of william paul
Sent: Tuesday, November 07, 2006 2:34 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] ovf query error
Hi:
I have created a OVF file to generate point files from MS
SqlServer and it's working OK. I can see the point but When I try to
query I get: msQueryByPoint() Search returned no results. No matching
record(s) found
In the ovf file I have:
<FID>UID</FID>
In Map file:
class
template.html
end
header header_template.html
footer footer_template.html
in template I have:
<tr>.....<td>[UID]</td>
The table in the SQL Server I have 3 columns:
UID type uniqueidentifier
x_coord type float
y_coord type float
I don't see where I do wrong
Thank you in advance
William
_____
Sponsored Link
Talk more and pay less. Vonage can save you up to $300 a year on
your phone bill. Sign up now.
<http://clk.atdmt.com/VON/go/yhxxxvon1080000017von/direct/01/>
_____
Sponsored Link
Free Uniden 5.8GHz Phone System with Packet8 Internet Phone Service
<http://www.getpacket8.net/yahoo2>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061108/1303277b/attachment.html
