Mapserver WMS ECW Datasource(s)
Ken Boss
Ken.Boss at DNR.STATE.MN.US
Wed Nov 8 11:36:02 EST 2006
Hello Andrew--
Mailing list: If you can't search at
http://lists.umn.edu/archives/mapserver-users.html (?), maybe try the
gmane archive at http://dir.gmane.org/gmane.comp.gis.mapserver.user.
Debugging: You can set DEBUG ON in either the MAP or LAYER object(s)
in your mapfile. The MapServer website is your friend - at
http://mapserver.gis.umn.edu, type "debug" into the search box at
upper right, and follow the links for Map and Layer for more info.
ECW support: is provided through GDAL. GDAL must be linked against
the ECW external libraries. The easiest way to manage that is to get it
all pre-built in FWTools (http://fwtools.maptools.org/); both Linux and
Windows distros are available.
HTH,
--Ken
>>> Andrew Hughes <azza at LISASOFT.COM> 11/6/2006 4:55 PM >>>
Hey All,
I would like to use ECW as a data source and have tried with the latest
fgs (mapserver v4.6 and also tried with another install v4.8.1) but I am
obviously having some trouble...... I have "rtfm" :
http://mapserver.gis.umn.edu/docs/howto/raster_data/#how-are-rasters-added-to-a-map-file
I apologise going to the list for this information because I'm sure it
has been covered before! But apparently you need a "LISTSERV password"
to search the mailing list archieve's (wtf???) and signing up to the
list did not provide me with a "LISTSERV password"....
Firstly.... is there a way to turn debugging on???
My only debug message is "msDrawMap(): Failed to draw layer named
'ecw'." Which is kind of obvious ;) ...
Secondly... perhaps there is something wrong with my layer definition
(my other layers in this file work perfect)???
LAYER
NAME "ecw"
DATA "/var/ecw/my.ecw"
TYPE RASTER
STATUS ON
MINSCALE 00000.0
MAXSCALE 1000000.0
END
Thirdly, perhaps my "FGS" installation does not allow me to read
ecw????????
azzabox:/opt/fgs# ./www/cgi-bin/mapserv -v
MapServer version 4.6.0-beta2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Finally, while I have you attention I know there are several free and
public datasources.... I have found some Landsat available here:
http://www.geotorrent.org/ and would welcome any further data
sources!
Many thanks in advance
--AH
p.s. I'm @ #mapserver
