Mapserver WMS ECW Datasource(s)
Frank Warmerdam
warmerdam at POBOX.COM
Fri Nov 10 17:15:07 EST 2006
Andrew Hughes wrote:
> Firstly.... is there a way to turn debugging on???
> My only debug message is "msDrawMap(): Failed to draw layer named
> 'ecw'." Which is kind of obvious ;) ...
Andrew,
You would add "DEBUG ON" to your layer definition.
However, I see your version string lacks DEBUG=MSDEBUG, so I don't think
the debug information will work anyways.
> Secondly... perhaps there is something wrong with my layer definition
> (my other layers in this file work perfect)???
> LAYER
> NAME "ecw"
> DATA "/var/ecw/my.ecw"
> TYPE RASTER
> STATUS ON
> MINSCALE 00000.0
> MAXSCALE 1000000.0
> END
This looks fine assuming the scales make sense, and that in actual
use you are enabling the raster layer (STATUS DEFAULT will force it
on).
> Thirdly, perhaps my "FGS" installation does not allow me to read ecw????????
> azzabox:/opt/fgs# ./www/cgi-bin/mapserv -v
> MapServer version 4.6.0-beta2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
You can't tell from the "mapserv -v" report whether GDAL or OGR are
built with particular formats. If you have installed the GDAL utilities
in your FGS tree as well, you can use "gdalinfo --formats" to list them
all or "gdalinfo --format ecw" to check if ECW is enabled. I suspect FGS
does not include ECW.
Also 4.6.0 beta2 is a bit oldish now. Perhaps you should consider
updating to the latest fgs builds.
> Finally, while I have you attention I know there are several free and
> public datasources.... I have found some Landsat available here:
> http://www.geotorrent.org/ and would welcome any further data sources!
Yes, I've got a mapserver based WMS running with one of the big south american
landsat ecw files off geotorrent.org, as a sort of proof of concept.
http://maps.gdal.org/
It *can* be done even if it is not trivial.
PS. The mapserver distributed in FWTools for linux does include ECW
support - http://fwtools.maptools.org/ That's what I'm using on maps.gdal.org
I believe.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
