write coordinates into SQL Server
David Lowther
dlowther at COORDINATESOLUTIONS.COM
Thu Nov 9 09:30:20 EST 2006
William,
Correct me if I am wrong, but what you are after here is how to translate an
image click into map coordinates, right? I suspect that the actual creation
of rows in SQL Server with the x, y coordinate values is straightforward.
In order to get the map coordinate from the image click you have to do a bit
of legwork since there is no direct method call for this in mapscript (that
I am aware of). You are using mapscript_csharp, right? Here's a bit of code
that may help you given that you have a mapextent, image width and height,
and image x, y click location:
Public Shared Function ConvertImageToGeo(ByVal imgExtent As GISExtent, ByVal
targExtent As GISExtent, ByVal imgPoint As GISPoint) As GISPoint
'//images have 0,0 in upper left corner - effectively switching
the orientation of the axis
Dim targPoint As New GISPoint
'//make sure imgpoint is inside imgextent
If Not imgPoint.x <= imgExtent.xMax Or Not imgPoint.x >=
imgExtent.xMin Or _
Not imgPoint.y <= imgExtent.yMax Or Not imgPoint.y >=
imgExtent.yMin Then
Return Nothing
End If
'//precentage along the x and y axis
Dim xPercent, yPercent As Double
xPercent = (imgPoint.x - imgExtent.xMin) / imgExtent.Width
yPercent = (imgPoint.y - imgExtent.yMin) / imgExtent.Height
'//since y axisorientation is backwards - take inverse
proportion of yfactor
yPercent = 1 - yPercent
'//calculate offset
Dim targXOffset, targYOffset As Double
targXOffset = targExtent.Width * xPercent
targYOffset = targExtent.Height * yPercent
'//calculate point
targPoint.x = targExtent.xMin + targXOffset
targPoint.y = targExtent.yMin + targYOffset
Return targPoint
End Function
If you are on the client side (javascript) you can use this if you populate
ImgW, ImgH, MapULX and MapULY beforehand.
function SetMapLoc(imgX, imgY){
var pX = imgX / ImgW;
var pY = imgY / ImgH;
var mapXAdd = MapW * pX;
var mapYAdd = MapH * pY;
MapX = MapULX + mapXAdd;
MapY = MapULY - mapYAdd;
MapX = MapX.toPrecision(8);
MapY = MapY.toPrecision(8);
Note that neither of these methods is very precise so if you are looking for
precision, you'll need something more sophisticated.
Hope that helps,
David Lowther
Coordinate Solutions, Inc.
501 N.E. 15th Street
Oklahoma City, OK 73104
405.246.9396 (Voice)
405.227.0781 (Fax)
www.coordinatesolutions.com
_____
From: william paul [mailto:williampaul28 at YAHOO.COM]
Sent: Wednesday, November 08, 2006 2:26 PM
Subject: write coordinates into SQL Server
Hi:
I would like to create point data by clicking on the map and write the
coordinates into SQl Server 2005. It's the opposite of OVF file for creating
points from 2 columns from a DBMS (like Sql Server, MySql)
When I click on the map I would like to take automatically the coordinates
and record them together with other attributes into a table (Sql Server|)
with 2 columns for x and y coordinates
Is it possible to do it?
I am using mapserver 4.10, dBox on IIS server and ASPX with Sql Server 2005
Thank you in advance
William
_____
Sponsored Link
For just $24.99/mo., Vonage offers unlimited local and long- distance
calling. Sign up
<http://clk.atdmt.com/VON/go/yhxxxvon1080000018von/direct/01/> now.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061109/5c0aa37a/attachment.html
