problems with zoom / layers
Blaise
bpicinbono at WORLDONLINE.FR
Thu Nov 9 22:02:52 EST 2006
hi there,
1 : check first that the layers you want queryable have a "template" line in
the mapfile. If not, they can't be queryable.
2 : might be. Make a quick string search with the original extent in all the
files and you'll see.
Regards
Blaise
Le jeudi 9 novembre 2006 20:54, Eduardo Zenaide a écrit :
> hi all,
> there's a way to display results from various layers, for example, i have
> three layers (city, country, province). when i do the query - i'm mounting
> my interface under gmap with ms4w - it results only the last layer. i would
> like to display results from all layers.
> other question: i have locked the screen on the map file as 760x500px. but,
> when i zoom in and use the query tool, the map extents to the original
> size. there's other place i should change the resolution?
> thanks in advance :)
