problems with zoom / layers
Blaise
bpicinbono at WORLDONLINE.FR
Fri Nov 10 11:07:55 EST 2006
Please Eduardo, post to the list so everybody can participate.
With gmap out of the box, you can do a mutliple query with the Rosa applet "i"
tool. Isn't it what you are looking for ?
Regards
Blaise
Le vendredi 10 novembre 2006 13:40, vous avez écrit :
> Blaise,
> about the layers, they all have a template line and work fine, but i want
> to know if i can see results from more than one layer at the same time.
> thanks
> 2006/11/10, Blaise <bpicinbono at worldonline.fr>:
> > hi there,
> > 1 : check first that the layers you want queryable have a "template" line
> > in
> > the mapfile. If not, they can't be queryable.
> > 2 : might be. Make a quick string search with the original extent in all
> > the
> > files and you'll see.
> > Regards
> > Blaise
> > Le jeudi 9 novembre 2006 20:54, Eduardo Zenaide a écrit:
> > > hi all,
> > > there's a way to display results from various layers, for example, i
> > have
> > > three layers (city, country, province). when i do the query - i'm
> > mounting
> > > my interface under gmap with ms4w - it results only the last layer. i
> > would
> > > like to display results from all layers.
> > > other question: i have locked the screen on the map file as 760x500px.
> > but,
> > > when i zoom in and use the query tool, the map extents to the original
> > > size. there's other place i should change the resolution?
> > > thanks in advance :)
