problems with zoom / layers
Eduardo Zenaide
ezenaide at GMAIL.COM
Fri Nov 10 09:03:30 PST 2006
sorry, gmail replied only to you, i didn't see it
what i want is to know if its possible to see, when i use the "i" tool over
a layer, results from all visible layers.
example: two layers (city, country) visibles, i click over one location,
let's say New York, it shows population from city layer AND name from
country layer.
thanks
2006/11/10, Blaise <bpicinbono at worldonline.fr>:
> Please Eduardo, post to the list so everybody can participate.
> With gmap out of the box, you can do a mutliple query with the Rosa applet
> "i"
> tool. Isn't it what you are looking for ?
> Regards
> Blaise
> Le vendredi 10 novembre 2006 13:40, vous avez écrit:
> > Blaise,
> > about the layers, they all have a template line and work fine, but i
> want
> > to know if i can see results from more than one layer at the same time.
> > thanks
> > > hi there,
> > > 1 : check first that the layers you want queryable have a "template"
> line
> > > in
> > > the mapfile. If not, they can't be queryable.
> > > 2 : might be. Make a quick string search with the original extent in
> all
> > > the
> > > files and you'll see.
> > > Regards
> > > Blaise
> > > Le jeudi 9 novembre 2006 20:54, Eduardo Zenaide a écrit:
> > > > hi all,
> > > > there's a way to display results from various layers, for example, i
> > > have
> > > > three layers (city, country, province). when i do the query - i'm
> > > mounting
> > > > my interface under gmap with ms4w - it results only the last layer.
> i
> > > would
> > > > like to display results from all layers.
> > > > other question: i have locked the screen on the map file as
> 760x500px.
> > > but,
> > > > when i zoom in and use the query tool, the map extents to the
> original
> > > > size. there's other place i should change the resolution?
> > > > thanks in advance :)
Eduardo Zenaide
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061110/3a5985d8/attachment.htm>
More information about the MapServer-users
