UTF8 PostGIS tables and labelitem
Alessandro Pasotti
ale.pas at TISCALI.IT
Sat Nov 11 07:56:47 EST 2006
Hello,
I have a mapfile UTF8 encoded wich reads data from an UTF8 PostGIS table (note
the NON ASCII labelitem "varietà":
#---------- start layer vig_camp_2004----------
LAYER
NAME "vig_camp_2004"
CONNECTION "host=localhost user=*** password=*** port=5433
dbname=database"
CONNECTIONTYPE postgis
TYPE POINT
DATA "the_geom from vig_camp_2004"
LABELITEM "varietà"
TEMPLATE "ttt"
STATUS default
CLASS
NAME "punti di campionamento"
COLOR 255 255 64
OUTLINECOLOR 0 0 0
SIZE 15
SYMBOL "star"
LABEL
ANTIALIAS true
COLOR 255 255 64
FONT "arial"
OUTLINECOLOR 192 0 0
POSITION ul
SIZE 7
TYPE truetype
END
END
PROJECTION
"init=epsg:3003"
END
METADATA
DESCRIPTION "Campionamenti 2004"
RESULT_FIELDS "proprietar,varietà"
LAYER_ENCODING "UTF-8"
QUERY_BY_POINT "ttt"
ATTRIBUTE_SEARCH "1"
WMS_SRS "epsg:3003"
WMS_TITLE "vig_camp_2004"
WMS_FEATURE_INFO_MIME_TYPE "text/html"
END
END
This is the error:
msDrawMap(): Image handling error. Failed to draw layer named 'vig_camp_2004'.
prepare_database(): Query error. Error executing POSTGIS DECLARE (the actual
query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
varietà::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text
from vig_camp_2004 WHERE the_geom && setSRID('BOX3D(1490836.03506098
4967565.5,1541436.33993902 4995227)'::BOX3D,
find_srid('','vig_camp_2004','the_geom') )'
Postgresql reports the error as 'ERROR: column "variet�" does not exist '
Note that the same DB and the same mapfile works fine on my local ubuntu
dapper (which is more UTF8 ready) but fails on my producion server which is
Debian based (and more LATIN9 oriented)
I tried to set default client encoding to UTF8 on the server but it did'nt
help.
It's clearly something to do with mapserver passing the query with the wrong
encoding or postgres not recognising it correctly.
Any hint would be highly appreciated.
--- further info ----
# /usr/lib/cgi-bin/mapserv -v
MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
# cat /etc/debian_version
testing/unstable
# file /mapfiles/mapfile.map
/mapfiles/mapfile.map: UTF-8 Unicode text
# psql -l
List of databases
Name | Owner | Encoding
database | postgres | UTF8
Alessandro Pasotti
itOpen - "Open Solutions for the Net Age"
w3: www.itopen.it
Linux User# 167502
