split two labels
percy
percyd at PDX.EDU
Tue Nov 14 09:50:17 EST 2006
Can you use that same keyword to label something with "boilerplate"
text, like
TEXT ("Route number: "[route_num])
One of my students was trying to get something like this working
yesterday, and I thought it should be possible...
Thx,
Percy
Michael Schulz wrote:
> Hi,
> not sure, if I understood the question correctly, but you can label
> one point with several attribute values, using the TEXT keyword in the
> class section of your mapfile:
> TEXT ([ATTRIBUTE1] - [ATTRIBUTE2])
> I don't think you can actually define 2 labelpositions within one
> layer. But you could use one layer to show the geometry with one label
> and e.g. an annotation layer for the other attribute label.
> HTH, Michael
> On 11/14/06, Humberto Cereser Ibanez
> <humberto at pastoraldacrianca.org.br> wrote:
>> Hi,
>> I want to show two labels, one to the left (LL) and another one to
>> the right (LR), separate for a hyphen.
>> Is there a way to visually split two labels?
>> example 123 - 4
>> Thanks
>> Pastoral da Criança
>> Curitiba - PR
