split two labels
    Humberto Cereser Ibanez
    humberto at PASTORALDACRIANCA.ORG.BR
    Tue Nov 14 05:13:55 PST 2006
Problem solved.
Tanks to Michael and sorry for my poor English.
LAYER
        NAME nexames
        GROUP "Nº Exames - Mutações"
        TYPE ANNOTATION
        CONNECTIONTYPE postgis
        CONNECTION "user=humberto dbname=mutacaoP53 host=localhost"
        DATA "the_geom from parana"
        PROJECTION
                "init=epsg:4291"
        END
        STATUS On
        LABELITEM "exames"
        CLASSITEM "exames"
        CLASS
                TEXT ([exames] - [mutacoes])
                EXPRESSION  /./
                COLOR -1 -1 -1
                LABEL
                        COLOR 0 0 0
                        OUTLINECOLOR 202 202 202
                        SHADOWCOLOR 202 202 202
                        TYPE TRUETYPE
                        FONT "sans"
                        ANTIALIAS TRUE
                        SIZE 6
                        POSITION lc
                        PARTIALS false
                END
        END
        TOLERANCE 0
        TOLERANCEUNITS meters
END     # Layer nexames
De: "Michael Schulz" <mschulz at webgis.de>
Data: Tue, 14 Nov 2006 11:51:16 +0100
Para: "Humberto Cereser Ibanez" <humberto at pastoraldacrianca.org.br>
Assunto: Re: [UMN_MAPSERVER-USERS] split two labels
not sure, if I understood the question correctly, but you can label
one point with several attribute values, using the TEXT keyword in the
class section of your mapfile:
TEXT ([ATTRIBUTE1] - [ATTRIBUTE2])
I don't think you can actually define 2 labelpositions within one
layer. But you could use one layer to show the geometry with one label
and e.g. an annotation layer for the other attribute label.
HTH, Michael
On 11/14/06, Humberto Cereser Ibanez <humberto at pastoraldacrianca.org.br> wrote:
> Hi,
> I want to show two labels, one to the left (LL) and another one to the right (LR), separate for a hyphen.
> Is there a way to visually split two labels?
> example 123 - 4
> Thanks
> Pastoral da Criança
> Curitiba - PR
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the MapServer-users
