problems with zoom / layers
Eduardo Zenaide
ezenaide at GMAIL.COM
Tue Nov 14 12:26:59 EST 2006
i haven't found anything so far...
anybody else could help?
thanks!
2006/11/10, Eduardo Zenaide <ezenaide at gmail.com>:
> variables returned from url:
> minx=-37.170347
> miny=-9.818007
> maxx=-36.313049
> maxy=-9.175033
> CMD=QUERY_POINT
> INPUT_TYPE=auto_rect
> INPUT_COORD=261%2C274%3B261%2C274
> original in the map file:
> -38.234122
> -11.52665
> -34.594394
> -8.133178
> it's like the query it's working fine, maybe it's some redraw after the
> query...
> i'm searching here, anyway.
> 2006/11/10, Blaise < bpicinbono at worldonline.fr>:
> > It seem's that the minx, miny, maxx, and maxy are not well passed to the
> > result page.
> > Can you chek for these variables and their value in the url of your
> > query
> > result page with "wrong" full extent compared to their value before the
> > query
> > or post it here ?
> > Blaise
> > Le vendredi 10 novembre 2006 19:26, Eduardo Zenaide a écrit:
> > > thanks a lot, Blaise! :D
> > > about my other question, i've changed in the map file the resolution,
> > but
> > > when i zoom in and do some query the map extents. it not resize, but
> > zoom
> > > out to its max. i've tried comment some functions to see if i can
> > identify
> > > where it happens but not sucessfully.
> > > any ideas?
> > > > Try switching MS_SINGLE to MS_MULTIPLE in the queryByPoint function
> > > > around line 510 in the gmap75.inc.php file. This should do the
> > trick;
> > > > check the doc
> > > > for more details :
> > http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/classes/ma
> > > >pobj Regards
> > > > Blaise
> > > > Le vendredi 10 novembre 2006 18:03, Eduardo Zenaide a écrit:
> > > > > sorry, gmail replied only to you, i didn't see it
> > > > > what i want is to know if its possible to see, when i use the "i"
> > tool
> > > > over
> > > > > a layer, results from all visible layers.
> > > > > example: two layers (city, country) visibles, i click over one
> > > > > location, let's say New York, it shows population from city layer
> > AND
> > > > > name from country layer.
> > > > > thanks
> > > > > 2006/11/10, Blaise <bpicinbono at worldonline.fr>:
> > > > > > Please Eduardo, post to the list so everybody can participate.
> > > > > > With gmap out of the box, you can do a mutliple query with the
> > Rosa
> > > > > > applet "i"
> > > > > > tool. Isn't it what you are looking for ?
> > > > > > Regards
> > > > > > Blaise
> > > > > > Le vendredi 10 novembre 2006 13:40, vous avez écrit:
> > > > > > > Blaise,
> > > > > > > about the layers, they all have a template line and work fine,
> > but
> > > > > > > i
> > > > > > want
> > > > > > > to know if i can see results from more than one layer at the
> > same
> > > > time.
> > > > > > > thanks
> > > > > > > > hi there,
> > > > > > > > 1 : check first that the layers you want queryable have a
> > > > "template"
> > > > > > line
> > > > > > > > in
> > > > > > > > the mapfile. If not, they can't be queryable.
> > > > > > > > 2 : might be. Make a quick string search with the original
> > extent
> > > > in
> > > > > > all
> > > > > > > > the
> > > > > > > > files and you'll see.
> > > > > > > > Regards
> > > > > > > > Blaise
> > > > > > > > Le jeudi 9 novembre 2006 20:54, Eduardo Zenaide a écrit:
> > > > > > > > > hi all,
> > > > > > > > > there's a way to display results from various layers, for
> > > > example,
> > > > > > > > > i
> > > > > > > > have
> > > > > > > > > three layers (city, country, province). when i do the
> > query -
> > > > i'm
> > > > > > > > mounting
> > > > > > > > > my interface under gmap with ms4w - it results only the
> > last
> > > > layer.
> > > > > > i
> > > > > > > > would
> > > > > > > > > like to display results from all layers.
> > > > > > > > > other question: i have locked the screen on the map file
> > as
> > > > > > 760x500px.
> > > > > > > > but,
> > > > > > > > > when i zoom in and use the query tool, the map extents to
> > the
> > > > > > original
> > > > > > > > > size. there's other place i should change the resolution?
> > > > > > > > > thanks in advance :)
> Eduardo Zenaide
Eduardo Zenaide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061114/e838b8ee/attachment.html
