problems with zoom / layers
Eduardo Zenaide
ezenaide at GMAIL.COM
Tue Nov 14 13:51:03 EST 2006
ok, i've found that the zoom itself can be the problem.
when i use it, it returns the map extent from map file all the time. i think
when i query, it return to previous map extent, wich is wrong! by the way,
query tool returns the correct map extent:
map extent (map file): -38.234122 -11.52665 -34.594394 -8.133178
test 1.
zoom:
minx=-38.676573 / miny=-11.526650 / maxx=-34.151943 / maxy=-8.133178
query:
minx=-36.176120 / miny=-9.562008 / maxx=-35.771284 / maxy=-9.258382
test 2.
zoom:
query:
minx=-38.062374 / miny=-9.591776 / maxx=-37.760732 / maxy=-9.365544
test 3.
zoom:
query:
minx=-35.312868 / miny=-8.988244 / maxx=-35.080683 / maxy=-8.814105
(ok, its not the exactly map extents, but the extent less 10% i think - gmap
do this to avoid borders)
so, now, i only have to figure how to use map extent returned from query
replacing the older - the wrong one returned from zoom.
any ideas?
2006/11/14, Eduardo Zenaide <ezenaide at gmail.com>:
> i haven't found anything so far...
> anybody else could help?
> thanks!
> 2006/11/10, Eduardo Zenaide <ezenaide at gmail.com>:
> > variables returned from url:
> > minx=-37.170347
> > miny=-9.818007
> > maxx=-36.313049
> > maxy=-9.175033
> > CMD=QUERY_POINT
> > INPUT_TYPE=auto_rect
> > INPUT_COORD=261%2C274%3B261%2C274
> > original in the map file:
> > -38.234122
> > -11.52665
> > -34.594394
> > -8.133178
> > it's like the query it's working fine, maybe it's some redraw after the
> > query...
> > i'm searching here, anyway.
> > 2006/11/10, Blaise < bpicinbono at worldonline.fr>:
> > > It seem's that the minx, miny, maxx, and maxy are not well passed to
> > > the
> > > result page.
> > > Can you chek for these variables and their value in the url of your
> > > query
> > > result page with "wrong" full extent compared to their value before
> > > the query
> > > or post it here ?
> > > Blaise
> > > Le vendredi 10 novembre 2006 19:26, Eduardo Zenaide a écrit:
> > > > thanks a lot, Blaise! :D
> > > > about my other question, i've changed in the map file the
> > > resolution, but
> > > > when i zoom in and do some query the map extents. it not resize, but
> > > zoom
> > > > out to its max. i've tried comment some functions to see if i can
> > > identify
> > > > where it happens but not sucessfully.
> > > > any ideas?
> > > > > Try switching MS_SINGLE to MS_MULTIPLE in the queryByPoint
> > > function
> > > > > around line 510 in the gmap75.inc.php file. This should do the
> > > trick;
> > > > > check the doc
> > > > > for more details :
> > > > > http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/classes/ma
> > > > >pobj Regards
> > > > > Blaise
> > > > > Le vendredi 10 novembre 2006 18:03, Eduardo Zenaide a écrit:
> > > > > > sorry, gmail replied only to you, i didn't see it
> > > > > > what i want is to know if its possible to see, when i use the
> > > "i" tool
> > > > > over
> > > > > > a layer, results from all visible layers.
> > > > > > example: two layers (city, country) visibles, i click over one
> > > > > > location, let's say New York, it shows population from city
> > > layer AND
> > > > > > name from country layer.
> > > > > > thanks
> > > > > > > Please Eduardo, post to the list so everybody can participate.
> > > > > > > With gmap out of the box, you can do a mutliple query with the
> > > Rosa
> > > > > > > applet "i"
> > > > > > > tool. Isn't it what you are looking for ?
> > > > > > > Regards
> > > > > > > Blaise
> > > > > > > Le vendredi 10 novembre 2006 13:40, vous avez écrit:
> > > > > > > > Blaise,
> > > > > > > > about the layers, they all have a template line and work
> > > fine, but
> > > > > > > > i
> > > > > > > want
> > > > > > > > to know if i can see results from more than one layer at the
> > > same
> > > > > time.
> > > > > > > > thanks
> > > > > > > > 2006/11/10, Blaise <bpicinbono at worldonline.fr>:
> > > > > > > > > hi there,
> > > > > > > > > 1 : check first that the layers you want queryable have a
> > > > > "template"
> > > > > > > line
> > > > > > > > > in
> > > > > > > > > the mapfile. If not, they can't be queryable.
> > > > > > > > > 2 : might be. Make a quick string search with the original
> > > extent
> > > > > in
> > > > > > > all
> > > > > > > > > the
> > > > > > > > > files and you'll see.
> > > > > > > > > Regards
> > > > > > > > > Blaise
> > > > > > > > > Le jeudi 9 novembre 2006 20:54, Eduardo Zenaide a écrit:
> > > > > > > > > > hi all,
> > > > > > > > > > there's a way to display results from various layers,
> > > for
> > > > > example,
> > > > > > > > > > i
> > > > > > > > > have
> > > > > > > > > > three layers (city, country, province). when i do the
> > > query -
> > > > > i'm
> > > > > > > > > mounting
> > > > > > > > > > my interface under gmap with ms4w - it results only the
> > > last
> > > > > layer.
> > > > > > > i
> > > > > > > > > would
> > > > > > > > > > like to display results from all layers.
> > > > > > > > > > other question: i have locked the screen on the map file
> > > as
> > > > > > > 760x500px.
> > > > > > > > > but,
> > > > > > > > > > when i zoom in and use the query tool, the map extents
> > > to the
> > > > > > > original
> > > > > > > > > > size. there's other place i should change the
> > > resolution?
> > > > > > > > > > thanks in advance :)
> > Eduardo Zenaide
> Eduardo Zenaide
Eduardo Zenaide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061114/1d9fdfe8/attachment.html
