filter rectangle
Gail Long
codeburg at HOTMAIL.COM
Tue Nov 14 20:08:42 EST 2006
A quick ?
I want to set a filter to work in a rectangle within the extents of a map
and generate the image using shp2img. How do I limit the filter to the rect
in the mapfile? I'm using POSTGIS layers.
| Filter area |
map area
LAYER
NAME fadapar ## Search layer for Parcels
STATUS on
DATA "the_geom from (SELECT parcels.oid AS oid, parcels.the_geom as
the_geom, parcels.primowner as primowner, parcels.parcel as
parcel,parcels.acres as acres, parcels.gid as gid from parcels) as oid USING
UNIQUE oid USING SRID=-1"
CONNECTIONTYPE postgis
CONNECTION "user=user password=pass dbname=db host=localhost"
TYPE POLYGON
LABELITEM 'parcel'
CLASSITEM 'ACRES'
TEMPLATE void
FILTER ' ACRES > 10 and ACRES <= 80 '
CLASS
NAME 'Filter Matches'
STYLE
OUTLINECOLOR 0 0 0
COLOR 255 255 0
END
TEXT ([PARCEL]|[PRIMOWNER]|[ACRES])
LABEL
POSITION cc
TYPE truetype
FONT verdana-bold
SIZE 3
WRAP '|'
END
END
END
Things are only difficult while you don't understand them.
_________________________________________________________________
All-in-one security and maintenance for your PC. Get a free 90-day trial!
http://clk.atdmt.com/MSN/go/msnnkwlo0050000002msn/direct/01/?href=http://www.windowsonecare.com/?sc_cid=msn_hotmail
