dbox legend question
Sam Young
samnyoung at HOTMAIL.COM
Wed Nov 15 10:43:07 EST 2006
The checkboxes for my legend in my dbox applications are not turned on for
active layers, nor do they change anything if I check/uncheck them and
redraw the map. The image that dislpays the color and shape of the layers
is also not being displayed. I get the following two errors in the
Javascript console:
Error: xEvent is not defined
Source File: http://localhost/src/javascript/mapserver/dbox.js
Line: 486
Error: xml declaration not at start of external entity
Source File:
http://localhost/cgi-bin/make_dlegend_xml_cgi.py?map=/ms4w/Apache/htdocs/sunvalley.map&server=localhost
Line: 2, Column: 1
Source Code:
<?xml version="1.0" ?>^
I have an "alert" in my code here:
// legend setup
var legend_xml = get_content(config.dlegend_xml_executable + "?map=" +
config.mapfile + "&server=" + config.dlegend_server);
alert(legend_xml);
legend.initialize("legend_container", legend_xml);
legend.setHandler(DLEGEND_CLICK, ms.setLayer);
ms.draw();
This alert doesn't produce any error messages.
Thanks in advance for any suggestions.
Sam
_________________________________________________________________
All-in-one security and maintenance for your PC. Get a free 90-day trial!
http://clk.atdmt.com/MSN/go/msnnkwlo0050000002msn/direct/01/?href=http://www.windowsonecare.com/?sc_cid=msn_hotmail
