Combination Apache + Php Problems
Delfos, Jacob
Jacob.Delfos at MAUNSELL.COM
Thu Nov 16 18:10:34 EST 2006
Hi Karin,
Don't double up on the definitions in httpd.conf. If it's already in there, it ought to work.
Are you sure the root directory of your webserver is where you think it is? Can you open up any other file in that same directory? A normal HTML file? If so, there's something wrong with PHP. If not, your ServerRoot in httpd.conf isn't set right.
I have also heard of people getting a "cannot be found" error if php isn't running properly because of a missing DLL. But I suppose this is not the case now. Are you using MS4W out of the box? Did you change anything?
Regards,
Jacob
» -----Original Message-----
» From: Karin Kampitsch [mailto:Karin_Kampitsch at gmx.at]
» Sent: 16 November 2006 19:44
» To: Delfos, Jacob
» Subject: Re: [UMN_MAPSERVER-USERS] Combination Apache + Php Problems
» Hi Jacob,
» Thank you for your information!
» There already exists such expressions in the httpd.conf file:
» ScriptAlias /cgi-bin/ "/ms4w/Apache/cgi-bin/"
» AddType application/x-compress .Z
» AddType application/x-gzip .gz .tgz
» AddType application/x-httpd-php .php5 .php4 .php3 .phtml .php
» Action application/x-httpd-php /cgi-bin/php-cgi.exe
» I tried it anyway and added these expressions:
» ScriptAlias /php/ "/ms4w/Apache/php/"
» AddType application/x-httpd-php .phtml
» Action application/x-httpd-php "/cgi-bin/php-cgi.exe" (my
» php-cgi.exe is in the cgi-bin directory)
» But it still does not work.
» My error message was, when I tried to open the "karin.php"
» file in the Url with http://localhost/karin.php, that "he
» cannot find the web page".
» The file "karin.php" is situated in the root directory of Apache.
» So i do not know whats wrong!
» Maybe you have an idea?
» Best regards,
» karin
» -------- Original-Nachricht --------
» Datum: Thu, 16 Nov 2006 07:59:17 +0800
» Von: "Delfos, Jacob" <Jacob.Delfos at MAUNSELL.COM>
» An: MAPSERVER-USERS at LISTS.UMN.EDU
» Betreff: Re: [UMN_MAPSERVER-USERS] Combination Apache + Php Problems
» > Hi Karin,
» > Can you please elaborate on the "did not work" bit?
» > What errors are you getting?
» > The core bit in the apache configuration (httpd.conf) is this:
» > ScriptAlias /php/ "/php/"
» > AddType application/x-httpd-php .php
» > AddType application/x-httpd-php .phtml
» > Action application/x-httpd-php "/php/php-cgi.exe"
» > This makes Apache execute PHP files. You may have to adjust
» it to suit
» > your setup. And make sure to restart Apache after changes
» to httpd.conf.
» > Regards,
» > Jacob
» > » -----Original Message-----
» > » From: UMN MapServer Users List
» > » [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Karin
» Kampitsch
» > » Sent: 15 November 2006 21:54
» > » To: MAPSERVER-USERS at LISTS.UMN.EDU
» > » Subject: [UMN_MAPSERVER-USERS] Combination Apache + Php Problems
» > » Dear Mailing List,
» > » I downloaded the mapserver package 4.8.4. In this package
» > » also the Apache Version 2.0.58 and the Php version 5.1.4
» is included.
» > » I tried to open a php file, but it did not work! And so I
» > » studied all the installation and configuration instructions
» > » and this made me really confusing!
» > » So do you know, is there anything I must do with the
» > » different files in the Apache directory??? Or is there a
» > » problem with the versions of Apache and PHP!
» > » It would be very nice, if you could help me!
» > » Yours desperate
» > » karin
» > » "Ein Herz für Kinder" - Ihre Spende hilft! Aktion:
» > » www.deutschlandsegelt.de
» > » Unser Dankeschön: Ihr Name auf dem Segel der 1. deutschen
» > » America's Cup-Yacht!
