ODBC for SQL Server 2000 not working
Steve White
swhite at URGTECH.CO.UK
Fri Nov 17 10:21:40 EST 2006
Further investigations using SQL Profiler shows that it is hitting the DB
and running the command.
However, I still get this error msg on the map:
msOGRFileNextShape(): OGR error. SetAttributeFilter() not supported on
ExecuteSQL() results.
This happens for GetMap and GetFeatureInfo requests.
Any clues on what's going wrong?
Thanks,
Steve
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Steve White
Sent: 17 November 2006 14:49
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] ODBC for SQL Server 2000 not working
I'm running SQL Server 2000 on a windows 2003 box. I've created an ovf file
and tested that it returns data, all good.
When I try to use this in my mapfile it doesn't return anything.
LAYER
NAME Test
TYPE POINT
LABELCACHE ON
CONNECTIONTYPE OGR
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer name='test'>
<SrcDataSource>ODBC:user/pwd at DSNName</SrcDataSource>
<SrcSQL>EXEC
GM_GetSingleRecord 2076</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField
encoding='PointFromColumns' y='Latitude' x='Longitude'/>
</OGRVRTLayer>
</OGRVRTDataSource>"
METADATA
"wms_title" "test"
"gml_include_items" "all"
"wms_include_items" "all"
END
PROJECTION
"init=epsg:4326"
END
STATUS ON
DATA "test"
TEMPLATE
"E:\Inetpub\wwwroot\Map\Data\test_query_template.html"
CLASS
SYMBOL 'circle'
SIZE 7
COLOR 0 0 0
METADATA
"wms_feature_info_mime_type" "text/html"
END # end of class metadata
TEMPLATE
END # end of class
END #end of layer
It's almost as if mapserver can't use my system DSN.
If I fire a GetFeatureInfo request on that layer I get this error:
I'm running out of ideas on this.
Can anyone help me out?
Thanks,
Steve
No virus found in this outgoing message.
Checked by AVG.
Version: 7.5.431 / Virus Database: 268.14.6/536 - Release Date: 16/11/2006
15:51
No virus found in this incoming message.
Checked by AVG.
15:51
Checked by AVG.
15:51
