ODBC for SQL Server 2000 not working
Steve White
swhite at URGTECH.CO.UK
Fri Nov 17 10:43:23 EST 2006
Thanks Frank.
Can you point me to a place where I get the latest build that contains a fix
for this please.
Steve
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Frank Warmerdam
Sent: 17 November 2006 19:00
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] ODBC for SQL Server 2000 not working
Steve White wrote:
> I'm running SQL Server 2000 on a windows 2003 box. I've created an ovf
> file and tested that it returns data, all good.
> When I try to use this in my mapfile it doesn't return anything.
> It's almost as if mapserver can't use my system DSN.
> If I fire a GetFeatureInfo request on that layer I get this error:
> msOGRFileNextShape(): OGR error. SetAttributeFilter() not supported on
> ExecuteSQL() results.
Steve,
You need an updated GDAL/OGR. I think this bug was fixed post 1.3.2 so you
might need a nightly snapshot.
Sorry, this has been a cause of much agony and knashing of teeth.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGeo, http://osgeo.org
No virus found in this incoming message.
Checked by AVG.
Version: 7.5.431 / Virus Database: 268.14.6/536 - Release Date: 16/11/2006
15:51
No virus found in this outgoing message.
Checked by AVG.
15:51
