ODBC for SQL Server 2000 not working
Eduardo Patto Kanegae
epk.lists at GMAIL.COM
Fri Nov 17 10:57:38 EST 2006
Frank,
Latest FWtools for windows should also fix this?
best
http://www.webmapit.com.br
On 11/17/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Steve White wrote:
> > I'm running SQL Server 2000 on a windows 2003 box. I've created an ovf
> file
> > and tested that it returns data, all good.
> > When I try to use this in my mapfile it doesn't return anything.
> > It's almost as if mapserver can't use my system DSN.
> > If I fire a GetFeatureInfo request on that layer I get this error:
> > msOGRFileNextShape(): OGR error. SetAttributeFilter() not supported on
> > ExecuteSQL() results.
> Steve,
> You need an updated GDAL/OGR. I think this bug was fixed post 1.3.2 so
> you
> might need a nightly snapshot.
> Sorry, this has been a cause of much agony and knashing of teeth.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061117/c72952ab/attachment.html
