raster projector
Yves Jacolin
yjacolin at FREE.FR
Fri Nov 17 13:26:38 EST 2006
Try to use gdal_translate or gdalwrap to change projection. You can do it for
all of your raster files.
Y.
Le Vendredi 17 Novembre 2006 19:08, John Smith a écrit :
> mapserver rocks on-the-fly!
> now what's the best way to avoid on-the-fly proj because that decreases
> performance. do i have to manually rectify geotiff to vector in arcmap
> (think human error)?
> thanks a bunch man
> jzs
> http://mapserver.gis.umn.edu/docs/howto/raster_data/#raster-display-perform
>ance-tips
> On 11/16/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > John Smith wrote:
> > > guys,
> > > trying to put a geotiff in- works but not right. here's what's
> > happening:
> > > i download the geotiff from national atlas. when i give no proj info
> > > under LAYER it shows up but not where it should (nwis). so i copy MAP
> > > proj to LAYER proj hoping for some on-the-fly magic- again it shows up
> > > but nwis.
> > > well i go over to proj_list
> > > <http://www.remotesensing.org/geotiff/proj_list/> and look up the epsg
> > > (EPSG?) code (9820) from metadata but it throws the
> > > "msProcessProjection(): Projection library error. no options found in
> > > 'init' file" error. then i try all epsg codes given by gdalinfo ;) but
> > > same error. although when i try the MAP epsg code (4326) it shows up
> > > but nwis.
> > > so what's wrong here? think proj.exe geod.exe cs2cs.exe libgeotiff
> > > listgeo'd help? now i don't think wld is needed because it's included
> > > with the geotiff but i've tried with wld and no luck. i just hope i
> > > don't have to rectify in arcmap. btw IMAGETYPE=png24 in case that
> > matters.
> > John,
> > I don't believe there is an EPSG code corresponding to this coordinate
> > system:
> > PROJCS["TIFF 6.0, GeoTIFF Revision 1.0",
> > GEOGCS["WGS 84",
> > DATUM["WGS_1984",
> > SPHEROID["WGS 84",6378137,298.2572235630016,
> > AUTHORITY["EPSG","7030"]],
> > AUTHORITY["EPSG","6326"]],
> > PRIMEM["Greenwich",0],
> > UNIT["degree",0.0174532925199433],
> > AUTHORITY["EPSG","4326"]],
> > PROJECTION["Lambert_Azimuthal_Equal_Area"],
> > PARAMETER["latitude_of_center",45],
> > PARAMETER["longitude_of_center",-100],
> > PARAMETER["false_easting",0],
> > PARAMETER["false_northing",0],
> > UNIT["metre",1,
> > AUTHORITY["EPSG","9001"]]]
> > But the corresponding PROJECTION block to put in the LAYER definition
> > is:
> > PROJECTION
> > "+proj=laea +lat_0=45 +lon_0=-100 +x_0=0 +y_0=0 +datum=WGS84 +units=m"
> > END
> > At one time you could also put:
> > PROJECTION
> > "AUTO"
> > END
> > and MapServer would read it from the geotiff file, but I'm not sure if
> > this
> > still works.
> > Best regards,
> >----- I set the clouds in motion - turn up | Frank Warmerdam,
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush | President OSGeo,
> > http://osgeo.org
Yves Jacolin
http://yjacolin.gloobe.org
