problem with MapServer global projection
percy
percyd at PDX.EDU
Mon Nov 20 13:16:59 EST 2006
Hi John,
Do you have a Projection object defined in your Layer object, too?
You probably need something like:
projection
"init=epsg:4326"
end
If you are using DD...
MS needs to know what coordinate system your data is in before it can
reproject it.
Percy
John Daly wrote:
> All,
> I'm a new MapServer user and list member, and I'd like to say hello to
> everyone. I'm also running into a problem trying to create a global map
> projection, and I would appreciate any and all feedback. I'm trying to
> use the projection example in Web Mapping illustrated, but although I
> have Proj4 support compiled in to MS, it does not seem to be actually
> using the new units and projection defined in my global.map file:
> MAP
> CONFIG "PROJ_LIB" "/usr/local/share/proj"
> PROJECTION
> "init=epsg:42304"
> END
> # PROJECTION
> # "proj=lcc"
> # "ellps=GRS80"
> # "lat_0=49"
> # "lon_0=-95"
> # "lat_1=49"
> # "lat_2=77"
> # "datum=NAD83"
> # "units=m"
> # "no_defs"
> # END
> I've tried both approaches, and neither works. The verbose switch to
> MapServer prints out:
> ./cgi-bin/mapserv -v
> MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=GEOS INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE
> ...and i'm using version 4.5 of Proj4. both were compiled from source
> on RedHat 9
> I do not getting any actual error message, just a failure to correctly
> use the new projection. Has anyone run across this? Is there an easy
> way to test if my proj4 support is not configured correctly?
> Thanks,
> John
David Percy
Geospatial Data Manager
Geology Department
Portland State University
http://gisgeek.pdx.edu
503-725-3373
