Personal geodatabase layer not working.
Paul Moen
pmoen at ND.GOV
Wed Nov 29 10:34:32 EST 2006
I have a dsn named 'thecounty' set up to access a Personal Geodatabase.
When I use the following command,
ogrinfo Pgeo:thecounty votes
I get the following output,
INFO: Open of `PGeo:thecounty'
using driver `PGeo' successful.
Layer name: Votes
Geometry: Unknown (any)
Feature Count: 3
Extent: (2785689.942372, 524554.643027) - (2857978.115425, 559998.112040)
Layer SRS WKT:
PROJCS["NAD_1983_StatePlane_North_Dakota_South_FIPS_3302_Feet",
GEOGCS["GCS_North_American_1983",
DATUM["North_American_Datum_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["False_Easting",1968500.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-100.5],
PARAMETER["Standard_Parallel_1",46.18333333333333],
PARAMETER["Standard_Parallel_2",47.48333333333333],
PARAMETER["Latitude_Of_Origin",45.66666666666666],
UNIT["Foot_US",0.3048006096012192]]
OBJECTID: Integer (11.0)
ADDRESS: String (255.0)
PRECINCT: String (255.0)
PARCEL: String (255.0)
CITYNAME: String (255.0)
POLL_LOCAT: String (255.0)
OGRFeature(Votes):1
OBJECTID (Integer) = 1
ADDRESS (String) = N/A
PRECINCT (String) = 09-20-02 & 09-20-03 & 09-20-04
PARCEL (String) = 26000001343010
CITYNAME (String) = ARTHUR
POLL_LOCAT (String) = Northern Cass School District
OGRFeature(Votes):2
OBJECTID (Integer) = 2
ADDRESS (String) = 550 MAIN ST
PRECINCT (String) = 09-22-02
PARCEL (String) = 08010011629000
POLL_LOCAT (String) = Arthur Community Hall
OGRFeature(Votes):3
OBJECTID (Integer) = 3
ADDRESS (String) = 17150 25TH ST SE
PRECINCT (String) = 09-22-06
PARCEL (String) = 09020011904000
CITYNAME (String) = ARGUSVILLE
POLL_LOCAT (String) = Argusville Fire Hall
Which leads me to believe that things are working properly. But, when I add
the following layer to my mapfile,
LAYER
NAME votes
TYPE POINT
GROUP "TEST"
CONNECTIONTYPE ogr
CONNECTION "PGeo:thecounty"
DATA "Votes"
STATUS ON
CLASS
NAME "votes"
STYLE
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
END
END
I get no errors, but nothing is displayed on my map. The projection of my
map is the same as the Projection in the personal geodatabase.
Anyone have any ideas?
Thank you,
Paul
