Personal geodatabase layer not working.
Paul Moen
pmoen at ND.GOV
Wed Nov 29 11:27:33 EST 2006
I created a personal geodatabase with only 3 records in each feature class.
One has 3 counties as polygons. The other is a point layer with only three
points. Maybe I messed up when I created the geodatabase.
On 11/29/06 10:12 AM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> On Nov 29, 2006, at 9:34 AM, Paul Moen wrote:
>> I have a dsn named 'thecounty' set up to access a Personal
>> Geodatabase.
>> When I use the following command,
>> ogrinfo Pgeo:thecounty votes
>> I get the following output,
>> INFO: Open of `PGeo:thecounty'
>> using driver `PGeo' successful.
>> I get no errors, but nothing is displayed on my map. The
>> projection of my
>> map is the same as the Projection in the personal geodatabase.
>> Anyone have any ideas?
> Still having problems with this?
> One question - when you installed that Actual Access driver, are you
> just using the trial? That only returns the first 3 records in any
> MDB, and those 3 might not be on your map region.
I am using the trial. I was hoping to make sure it works before spending
the money.
> try this:
> ogrinfo -al Pgeo:thecounty votes
Gives this output.
Layer name: Votes
Geometry: Unknown (any)
Feature Count: 3
Extent: (2785689.942372, 524554.643027) - (2857978.115425, 559998.112040)
Layer SRS WKT:
PROJCS["NAD_1983_StatePlane_North_Dakota_South_FIPS_3302_Feet",
GEOGCS["GCS_North_American_1983",
DATUM["North_American_Datum_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["False_Easting",1968500.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-100.5],
PARAMETER["Standard_Parallel_1",46.18333333333333],
PARAMETER["Standard_Parallel_2",47.48333333333333],
PARAMETER["Latitude_Of_Origin",45.66666666666666],
UNIT["Foot_US",0.3048006096012192]]
OBJECTID: Integer (11.0)
ADDRESS: String (255.0)
PRECINCT: String (255.0)
PARCEL: String (255.0)
CITYNAME: String (255.0)
POLL_LOCAT: String (255.0)
OGRFeature(Votes):1
OBJECTID (Integer) = 1
ADDRESS (String) = N/A
PRECINCT (String) = 09-20-02 & 09-20-03 & 09-20-04
PARCEL (String) = 26000001343010
CITYNAME (String) = ARTHUR
POLL_LOCAT (String) = Northern Cass School District
OGRFeature(Votes):2
OBJECTID (Integer) = 2
ADDRESS (String) = 550 MAIN ST
PRECINCT (String) = 09-22-02
PARCEL (String) = 08010011629000
POLL_LOCAT (String) = Arthur Community Hall
OGRFeature(Votes):3
OBJECTID (Integer) = 3
ADDRESS (String) = 17150 25TH ST SE
PRECINCT (String) = 09-22-06
PARCEL (String) = 09020011904000
CITYNAME (String) = ARGUSVILLE
POLL_LOCAT (String) = Argusville Fire Hall
> That should list the attributes and coordinates data for those first
> three features. Or the whole file if you bought the driver.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an
> illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
Paul T. Moen
pmoen at nd.gov
701-328-2434
701-328-3696 (fax)
ND State Water Commission
