Personal geodatabase layer not working.
William Kyngesburye
woklist at KYNGCHAOS.COM
Wed Nov 29 11:57:45 EST 2006
On Nov 29, 2006, at 10:27 AM, Paul Moen wrote:
> Gives this output.
(I guess the -al option is implied - same output)
Looks like Frank already replied and can look into it.
Frank, this is the result of my bug report about the PGEO driver:
http://bugzilla.remotesensing.org/show_bug.cgi?id=1367
For the PGEO driver in the GDAL Paul has, I simply commented out the
MDB Tools loading parts so that he can use a different Access ODBC
driver as configured in his odbc.ini. Also, as I've been doing with
all my GDAL builds, it uses iODBC instead of UnixODBC. Just so you
know.
I tried the Actual Access/iODBC combination a while back (Jan I
think) and it seemed to work. I don't remember how much I tested it,
so I don't know if I got geometry data returned.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
