Personal geodatabase layer not working.
Paul Moen
pmoen at ND.GOV
Wed Nov 29 12:25:15 EST 2006
So the consensus is that the odbc driver is the problem.
Sorry for the post in the wrong place, I thought I was doing something wrong
with my mapfile.
On 11/29/06 10:57 AM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> On Nov 29, 2006, at 10:27 AM, Paul Moen wrote:
>> Gives this output.
> (I guess the -al option is implied - same output)
> Looks like Frank already replied and can look into it.
> Frank, this is the result of my bug report about the PGEO driver:
> http://bugzilla.remotesensing.org/show_bug.cgi?id=1367
> For the PGEO driver in the GDAL Paul has, I simply commented out the
> MDB Tools loading parts so that he can use a different Access ODBC
> driver as configured in his odbc.ini. Also, as I've been doing with
> all my GDAL builds, it uses iODBC instead of UnixODBC. Just so you
> know.
> I tried the Actual Access/iODBC combination a while back (Jan I
> think) and it seemed to work. I don't remember how much I tested it,
> so I don't know if I got geometry data returned.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that
> the past isn't a fiction designed to account for the discrepancy
> between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
Paul
