Personal geodatabase layer not working.
Frank Warmerdam
warmerdam at POBOX.COM
Wed Nov 29 12:52:42 EST 2006
William Kyngesburye wrote:
> On Nov 29, 2006, at 10:27 AM, Paul Moen wrote:
>> Gives this output.
> (I guess the -al option is implied - same output)
> Looks like Frank already replied and can look into it.
> Frank, this is the result of my bug report about the PGEO driver:
> http://bugzilla.remotesensing.org/show_bug.cgi?id=1367
> For the PGEO driver in the GDAL Paul has, I simply commented out the MDB
> Tools loading parts so that he can use a different Access ODBC driver as
> configured in his odbc.ini. Also, as I've been doing with all my GDAL
> builds, it uses iODBC instead of UnixODBC. Just so you know.
> I tried the Actual Access/iODBC combination a while back (Jan I think)
> and it seemed to work. I don't remember how much I tested it, so I
> don't know if I got geometry data returned.
William,
It seems I missed the part in this discussion where it is ocurring on
MacOS X! Well, the file works fine for me on windows, so the issue might
be something with the odbc setup.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
