upgrading WKT error
Jeppe Lund Andersen
JXA at COWI.DK
Wed Nov 29 10:38:36 EST 2006
Hello
I have upgraded from 4.8.1 to mapserver 4.10
and gotten the files from ms4w_1.6
and using php 4.4.2 on a windows IIS.
this is using GDAL 1.3.2 and is installed with GEOS
the code I made works fine on 4.8.1 and can show the WKT strings Iam storing in the Database ( only problem is that GDAL is version 1.3.1 and does not support WKT strings over 512).
now in the new mapserver 4.10 I get this error
msOGRFileNextShape(): Column WKT requested for geometry, but it does not exist
I know that the WKT coln exist because it running on exact same code that I do on 4.8.1 and there it works fine.
Second error is if I try to use ms_shapeObjFromWkt()
$NewShapeFromWkt = ms_shapeObjFromWkt( $wktstreng['wkt'] );
I will get this error
GEOSShapeFromWKT(): Error reading WKT geometry "POLYGON ((524401.01456 6256859.53403,524393.08587 6256832.01146,524379.23346 6256832.1026,524389.25823 6256860.90105))"
is it because this is build with GEOS or is it because of the changed from mapserver 4.8 to 4.10 ?
Med venlig hilsen
Jeppe Lund Andersen
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061129/d77921ec/attachment.html
