Question on Javascript Pan not Working
Delfos, Jacob
Jacob.Delfos at MAUNSELL.COM
Wed Nov 29 23:24:36 PST 2006
Hi Jessica,
Given the syntax, I suspect your statement might need to be:
document.forms['mapserv'].submit();
But this appears to happen in your mapfile... Which is weird, because
your browser isn't supposed to be loading your mapfile, but your
template. Can you please check whether you are loading a .html template?
And what is your piece of code trying to do? Maybe send a larger piece
of code.
Regards,
Jacob
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of fend0009
> Sent: 30 November 2006 13:22
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Question on Javascript Pan not Working
> Hi all:
> I encountered a problem in constructing my interactive map.
> The navigation
> (pan) buttons do not work.
> The JavaScript Console returned the following error message
> Error: document.mapserv.submit is not a function
> Source File:
> http://maps.socsci.umn.edu/cgi-bin/mapserv?map=/home/fend0009/
> public_html/noise.map
> Line: 81
> Could someone please give me some guidance? I appreciate your time.
> Regards,
> Jessica Fendos
More information about the MapServer-users
