msDrawRaster(): Unable to access file
edfialk
wef1 at CEC.WUSTL.EDU
Mon Feb 26 12:53:58 PST 2007
Hi, I have many netCDF files I'm wishing to serve through MapServer, each of
them a different time.
My first step is to serve one file, which I can't even do.
The error I get is:
msDrawMap(): Image handling error. Failed to draw layer named 'RETRO'.
msDrawRaster(): Unable to access file. (RETRO_anthro_nox_1960.0.5x0.5.nc)
The file definitely has read writes and all, and it's in the same folder as
some of the other data sources I have successfuly read through MapServer, so
I check the file with gdalinfo and it starts out with:
[root at niceguy RETRO]# gdalinfo RETRO_anthro_nox_1960.0.5x0.5.nc
Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
Now I read when serving netCDF files through MapServer the file must be CF
compliant("!!!"), so does anyone know if this might have something to do
with it? Before I chop apart my map file, does anyone think this Conventions
attribute
might prevent my file from being properly read in MapServer?
Thanks for any help!
-Ed
View this message in context: http://www.nabble.com/msDrawRaster%28%29%3A-Unable-to-access-file-tf3296008.html#a9168906
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users
