AGG
Peter Bruton
peter.bruton at NRCAN.GC.CA
Thu Jun 14 09:24:44 EDT 2007
Hello;
I have been experimenting with AGG in MapServer (CVS April 26/2007) using
various OUTPUTFORMATs and found the results inconsistent. To experiment
with various OUTPUTFORMATs (DRIVERs and IMAGEMODEs), a series of mapfiles
were created that have a single line layer where all features are drawn as
black lines with a width of one pixel.
DRIVER GD/GIF and IMAGEMODE PC256
The lines were rendered as expected. I performed this test as a baseline.
http://dev.atlas.gc.ca/cgi-bin/mapserv_dev?map=/home/atlas/mapdata/english/pb_gd_gif_pc256.map&mode=map
DRIVER AGG/PC256 and IMAGEMODE RGBA
While anti-aliasing was present the pattern of the line was not consistent.
Sometimes a solid line and other times there were gaps in the line.
http://dev.atlas.gc.ca/cgi-bin/mapserv_dev?map=/home/atlas/mapdata/english/pb_agg_pc_rgba.map&mode=map
DRIVER AGG/PNG and IMAGEMODE RGBA
While anti-aliasing was present, the lines were gray and not black. In
addition the pattern of the line was not consistent. Sometimes a solid line
http://dev.atlas.gc.ca/cgi-bin/mapserv_dev?map=/home/atlas/mapdata/english/pb_agg_png_rgba.map&mode=map
DRIVER AGG/PNG24 and IMAGEMODE RGBA
http://dev.atlas.gc.ca/cgi-bin/mapserv_dev?map=/home/atlas/mapdata/english/pb_agg_png24_rgba.map&mode=map
DRIVER AGG/JPG and IMAGEMODE RGBA
While this produced the best rendering of the line, the background was
pixelated around the line.
http://dev.atlas.gc.ca/cgi-bin/mapserv_dev?map=/home/atlas/mapdata/english/pb_agg_jpg_rgba.map&mode=map
DRIVER AGG/GIF and IMAGEMODE RGBA
http://dev.atlas.gc.ca/cgi-bin/mapserv_dev?map=/home/atlas/mapdata/english/pb_agg_gif_rgba.map&mode=map
It is not clear to me why gray and/or lines with inconsistent patterns were
returned. Are the DRIVER/IMAGEMODE conbinations I am using not compatible
with one another? Or am I missing something else.
The symbol definition I am using for the lines in the mapfiles is:
SYMBOL
TYPE ELLIPSE
NAME solidline
POINTS
1 1
END
FILLED true
END
Any insight to the problems I am having is appreciated.
Peter Bruton
