Image projection question
Stephen Davies
sdc at SDC.COM.AU
Fri Jun 15 22:33:42 EDT 2007
G'day Frank.
Thank you again for your feedback.
My problem with displaying the shapefile was one of colour. When I added
a CLASS to the unit layer, it became visible.
I checked my spatial_ref_sys table and the 28354 definition is correct.
I tried expanding the map PROJECTON definition but this had no visible
effect.
What did have an effect however, was to change the map projection to:
PROJECTION
"init=epsg:28354"
END
This fixed the polygon location relative to the raster - but broke the
reference map. It no longer shows the map location.
As I think I mentioned earlier, this was the reason that I originally
chose eqc as the map projection. It was the only one I could find that
produced matching map, reference map and scale map.
I am attaching the complete map file that was used in this latest test.
If you could identify why the reference map has stopped working, I
think my whole problem might be solved.
Cheers and thanks,
Stephen
On Saturday 16 June 2007 00:18, you wrote:
> Stephen Davies wrote:
> > MAP
> > NAME benparts1
> > PROJECTION
> > "proj=eqc"
> > "lon_0=139.591e"
> > END
> Stephen,
> I suspect the above is your problem. The above definition will
> default to using the WGS84 as the datum, but everything else is GRS80
> (the GDA94 ellipsoid). Hmm, on review GRS80 is a very close match to
> WGS84 as an ellipsoid, so this isn't so likely. Nevertheless, it
> would make me feel better if you included an explicit ellipsoid.
> eg.
> PROJECTION
> "+proj=eqc +lon_0=139.59 +ellps=GRS80 +towgs84=0,0,0 +no_defs"
> END
> You mentioned you weren't able to get the shapefile to show:
> LAYER
> # CONNECTIONTYPE postgis
> NAME "unit"
> DATA "/var/shapefiles/CondoCitrus"
> CONNECTION "user=scldad dbname=benparts"
> STATUS default
> TYPE POLYGON
> # FILTER "unit_id in (0)"
> PROJECTION
> "init=epsg:28354"
> END
> MAXSCALE 5000000
> END
> I would suggest also commending out the CONNECTION. I assume the
> shapefile is /var/shapefiles/CondoCitrus.shp?
> You might also consider replacing init=epsg:28354 with the following
> definition just to be sure the expected definitions are being used.
> PROJECTION
> "+proj=utm +zone=54 +south +ellps=GRS80 +towgs84=0,0,0,0,0,0,0
> +units=m +no_defs" END
> You should also check the spatial_ref_sys table in postgis, to
> verify the same proj.4 string is being used there for SRID 28354.
> Best regards,
This email is for the person(s) identified above, and is confidential to
the sender and the person(s). No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
# Copyright Stephen Davies Consulting P/L 2005
# template map file for Agua Soil Database
MAP
NAME benparts1
PROJECTION
"init=epsg:28354"
END
SIZE 600 600
FONTSET "/var/www/html2/benparts/fonts.list"
SYMBOLSET "/var/www/html2/benparts/symbols"
UNITS METERS
IMAGETYPE jpeg
OUTPUTFORMAT
NAME jpeg
DRIVER "GD/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
FORMATOPTION "QUALITY=80"
END
IMAGECOLOR 255 255 255
WEB
template /var/www/html2/benparts/templates/test1.html
imagepath "/var/www/html2/tmp/"
imageurl "/tmp/"
END
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 94
END
STATUS ON
END
LAYER
TYPE RASTER
NAME "bkgrnd"
STATUS DEFAULT
PROJECTION
"init=epsg:28354"
END
DATA "/var/www/html2/benparts/rasters/SwanReach_Citrus_Mar07_2m.tif"
# OFFSITE 0 0 0
PROCESSING "DITHER=YES"
END
LAYER
NAME "geog"
DATA "geom from geog"
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4283"
END
CLASS
STYLE
# COLOR 233 233 233
OUTLINECOLOR 11 11 11
END
END
END
LAYER
NAME "unit"
DATA "geom from unit"
STATUS default
TYPE POLYGON
PROJECTION
"init=epsg:4283"
END
MAXSCALE 5000000
LABELITEM "name"
CLASSITEM "mstatus"
CLASS
# NAME "Unknown"
EXPRESSION "x"
STYLE
OUTLINECOLOR 127 127 127
END
LABEL
MINDISTANCE 150
POSITION CC
SIZE MEDIUM
COLOR 255 0 255
FORCE TRUE
END
END
CLASS
NAME "Saturated"
EXPRESSION "1"
STYLE
COLOR 0 168 255
END
LABEL
MINDISTANCE 150
POSITION CC
SIZE MEDIUM
COLOR 255 0 255
FORCE TRUE
END
END
CLASS
NAME "..."
EXPRESSION "2A"
STYLE
COLOR 0 255 0
END
LABEL
MINDISTANCE 150
POSITION CC
SIZE MEDIUM
COLOR 255 0 255
FORCE TRUE
END
END
CLASS
NAME ".. "
EXPRESSION "2B"
STYLE
COLOR 115 255 0
END
LABEL
MINDISTANCE 150
POSITION CC
SIZE MEDIUM
COLOR 255 0 255
FORCE TRUE
END
END
CLASS
NAME "."
EXPRESSION "2C"
STYLE
COLOR 168 255 168
END
LABEL
MINDISTANCE 150
POSITION CC
SIZE MEDIUM
COLOR 255 0 255
FORCE TRUE
END
END
CLASS
NAME "Refill Point"
EXPRESSION "2D"
STYLE
COLOR 214 255 168
END
LABEL
MINDISTANCE 150
POSITION CC
SIZE MEDIUM
COLOR 255 0 255
FORCE TRUE
END
END
CLASS
NAME "."
EXPRESSION "3A"
STYLE
COLOR 255 255 0
END
LABEL
MINDISTANCE 150
POSITION CC
SIZE MEDIUM
COLOR 255 0 255
FORCE TRUE
END
END
CLASS
NAME "Onset of Water Stress"
EXPRESSION "3B"
STYLE
COLOR 255 235 0
END
LABEL
MINDISTANCE 150
POSITION CC
SIZE MEDIUM
COLOR 255 0 255
FORCE TRUE
END
END
CLASS
NAME ".."
EXPRESSION "4A"
STYLE
COLOR 255 215 0
END
LABEL
MINDISTANCE 150
POSITION CC
SIZE MEDIUM
COLOR 255 0 255
FORCE TRUE
END
END
CLASS
NAME "..."
EXPRESSION "4B"
STYLE
COLOR 255 195 0
END
LABEL
MINDISTANCE 150
POSITION CC
SIZE MEDIUM
COLOR 255 0 255
FORCE TRUE
END
END
CLASS
NAME "Severe Water Stress"
EXPRESSION "5"
STYLE
COLOR 255 0 96
END
LABEL
MINDISTANCE 150
POSITION CC
SIZE MEDIUM
COLOR 255 0 255
FORCE TRUE
END
END
END
LAYER
NAME "cadt"
DATA "geom from cad"
STATUS DEFAULT
TYPE POINT
PROJECTION
"init=epsg:4283"
END
FILTER "gtype='T' and client_id=49"
CLASSITEM "type"
CLASS
EXPRESSION "201"
STYLE
COLOR 0 255 0
END
STYLE
SYMBOL "tree"
COLOR 0 255 0
SIZE 9
END
END
CLASS
EXPRESSION "754"
LABEL
MINDISTANCE 150
POSITION CR
SIZE TINY
COLOR 0 0 0
FORCE TRUE
END
TEXT 'WM'
STYLE
SYMBOL "dot"
COLOR 0 0 0
SIZE 5
END
END
CLASS
EXPRESSION "757"
LABEL
MINDISTANCE 150
POSITION CR
SIZE TINY
COLOR 0 0 0
FORCE TRUE
END
TEXT 'Bore'
STYLE
SYMBOL "dot"
COLOR 0 0 0
SIZE 5
END
END
CLASS
EXPRESSION "712"
STYLE
SYMBOL "stobie"
SIZE 4
COLOR 255 0 168
END
END
CLASS
EXPRESSION /./
STYLE
SYMBOL "dot"
COLOR 9 9 9
SIZE 5
END
END
END
LAYER
NAME "cadl"
STATUS DEFAULT
TYPE LINE
PROJECTION
"init=epsg:4283"
END
FILTER "gtype in ('L','P') and client_id=49"
CLASSITEM "type"
CLASS
EXPRESSION "908"
STYLE
SYMBOL "fence"
SIZE 10
COLOR 0 255 0
END
STYLE
SYMBOL "dot"
COLOR 0 255 0
SIZE 1
END
END
CLASS
EXPRESSION "712"
STYLE
SYMBOL "power"
SIZE 8
COLOR 255 0 168
END
STYLE
SYMBOL "dot"
COLOR 255 0 168
SIZE 1
END
END
CLASS
EXPRESSION "602"
STYLE
SYMBOL "dot"
COLOR 137 205 190
SIZE 1
END
END
CLASS
EXPRESSION /./
STYLE
COLOR 9 9 9
END
END
END
LAYER
NAME "probe"
DATA "geom from probe"
STATUS DEFAULT
TYPE POINT
# FILTER "probe_id in (0)"
PROJECTION
"init=epsg:4283"
END
MAXSCALE 5000000
LABELITEM "location"
CLASS
NAME "Probe (Right Click to select)"
STYLE
COLOR 0 214 0
SYMBOL 'circle'
SIZE 7
END
LABEL
MINDISTANCE 15
POSITION CR
SIZE SMALL
COLOR 0 0 0
FORCE TRUE
END
END
END
LAYER
NAME "bore"
DATA "geom from bore"
FILTER "id in (0)"
STATUS DEFAULT
TYPE POINT
PROJECTION
"init=epsg:4283"
END
LABELITEM "name"
CLASS
NAME "Bore"
STYLE
COLOR 0 0 214
SYMBOL 'circle'
SIZE 7
END
LABEL
MINDISTANCE 150
POSITION CR
SIZE TINY
COLOR 9 9 9
END
END
END
LAYER
NAME "weather"
DATA "geom from weather_station"
STATUS DEFAULT
TYPE POINT
FILTER "id in (0)"
PROJECTION
"init=epsg:4283"
END
LABELITEM "name"
CLASS
NAME "Weather Station"
STYLE
COLOR 214 0 0
SYMBOL 'circle'
SIZE 7
END
LABEL
MINDISTANCE 150
POSITION CR
SIZE TINY
COLOR 9 9 9
END
END
END
LAYER
NAME "onswitch"
DATA "geom from onswitch using unique id using SRID=4283"
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4283"
END
MAXSCALE 5000000
CLASS
STYLE
OUTLINECOLOR 0 0 255
MINWIDTH 3
END
END
END
LAYER
NAME 'copyright'
TYPE ANNOTATION
STATUS DEFAULT
TRANSFORM FALSE # coordinates are in pixels
FEATURE
POINTS 10 595 END
END
CLASS
LABEL
TYPE TRUETYPE
FONT arial
SIZE 8
COLOR 255 255 255
POSITION CR
END
TEXT 'Photography supplied by MAPLAND, Environment Information, Dept Environment & Heritage'
END
END
LAYER
NAME 'movie'
TYPE ANNOTATION
STATUS DEFAULT
FEATURE
POINTS 270 10 END
END
CLASS
LABEL
TYPE TRUETYPE
FONT arial
SIZE 10
COLOR 251 196 6
POSITION CR
END
TEXT 'Status at 2007-06-13 07:00:00 .'
END
END
# Start of reference map
REFERENCE
IMAGE /var/www/html2/benparts/refmaps/sa.png
EXTENT -1191229.87 -4230140.65 167981.11 -2872042.86
SIZE 120 120
STATUS ON
MINBOXSIZE 5
MAXBOXSIZE 100
COLOR 0 255 0
OUTLINECOLOR 0 0 0
MARKERSIZE 8
MARKER 'star'
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 0 0 0
LABEL
COLOR 255 255 255
SIZE TINY
END
STYLE 1
SIZE 200 2
COLOR 255 255 255
UNITS KILOMETERS
INTERVALS 2
TRANSPARENT TRUE
STATUS ON
END
END
