non-tiff (24 bit?) raster layers in 4.10
Attila Csipa
plists at PROMETHEUS.ORG.YU
Mon May 7 12:13:52 EDT 2007
On Monday 07 May 2007 17:43, Frank Warmerdam wrote:
> I think the most important step is to compare the gdalinfo reports on the
> original TIFF and the JPEG2000 file you produced. I *suspect* that the
Yes, upon checking it seems to be the issue, but is there a way to force the
world file (plain jpeg misses it too) ? The funny part is that f.e. the PNG
driver _does_ find the georeferencing info.
Driver: JPEG2000/JPEG-2000 part 1 (ISO/IEC 15444-1)
Size is 5000, 5000
Coordinate System is `'
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 5000.0)
Upper Right ( 5000.0, 0.0)
Lower Right ( 5000.0, 5000.0)
Center ( 2500.0, 2500.0)
Driver: JPEG/JPEG JFIF
Size is 5000, 5000
Corner Coordinates:
Band 1 Block=5000x1 Type=Byte, ColorInterp=Red
Band 2 Block=5000x1 Type=Byte, ColorInterp=Green
Band 3 Block=5000x1 Type=Byte, ColorInterp=Blue
Driver: PNG/Portable Network Graphics
Size is 5000, 5000
Origin = (7579500.000000,4800500.000000)
Pixel Size = (0.10000000,-0.10000000)
Corner Coordinates:
Upper Left ( 7579500.000, 4800500.000)
Lower Left ( 7579500.000, 4800000.000)
Upper Right ( 7580000.000, 4800500.000)
Lower Right ( 7580000.000, 4800000.000)
Center ( 7579750.000, 4800250.000)
Driver: GIF/Graphics Interchange Format (.gif)
Size is 5000, 5000
Corner Coordinates:
Band 1 Block=5000x1 Type=Byte, ColorInterp=Palette
