Raster layer - Howto? {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Thu Nov 1 09:51:12 EDT 2007
Hi Pascal,
A world file contains the six parameters of an affine transformation like
x1 = Ax + By + C
y1 = Dx + Ey + F
All parameters are in separate rows in A, D, B, E, C, F order
example:
0.15 (A) pixel size in nature in x direction (e.g. 15 cm resolution)
0.0 (D) depends on rotational angle, afaik it must be zero for mapserver
0.0 (B) same as above
-0.15 (E) negative pixel size in nature in y direction
1234.56 (C) x position of the center of the pixel at upper-left corner
4567.89 (F) y position of the center of the pixel at upper-left corner
Zoltan
On Thu, 1 Nov 2007, Pascal Ehlert wrote:
> Gregor Mosheh wrote:
>> I don't have a world file handy at the moment, but it only took me about 5
>> minutes to learn it for the first time. Name the worldfile
>> land_shallow_topo_8192.tfw and gdalinfo will automagically detect it and
>> suddenly change its tone. :)
> Sorry, apparently I'm not as clever as you are.. ;-)
> I'm totally new to the GIS sector and thus don't really understand the terms
> used there and the techniques behind.
> Would you (or someone else, of course) mind giving me an example world file
> with a few comments, so that I can understand it?
> Unfortunately I couldn't find such an example on the web.
> Thank you again.
> Pascal
