Raster layer - Howto? {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Thu Nov 1 13:16:35 EDT 2007
Hi Pascal,
Use mustnot mix meters and degree, use the same unit for these
parameters. It may depend on what projection you use.
Zoltan
On Thu, 1 Nov 2007, Pascal Ehlert wrote:
> Siki Zoltan wrote:
>> 0.15 (A) pixel size in nature in x direction (e.g. 15 cm resolution)
>> 0.0 (D) depends on rotational angle, afaik it must be zero for mapserver
>> 0.0 (B) same as above
>> -0.15 (E) negative pixel size in nature in y direction
>> 1234.56 (C) x position of the center of the pixel at upper-left corner
>> 4567.89 (F) y position of the center of the pixel at upper-left corner
> Okay, I was able to figure out the first four values now!
> The data has a resolution of 1km/px so I want something like
> 1000.00
> 0.00
> 0.00
> -1000.00
> there, is that correct?
> The only thing I'm unsure about are the last two values.
> It is an image of the whole world, so shouldn't that be something like
> -180.00 for the first value and 90.00 for the last?
> When using these values gdalinfo gives me a strange output for the offsets
> which can't be correct.
> Sorry to bother you again.
> Pascal
