QueryByRect problem in PHPmapscript
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Nov 1 11:08:07 EDT 2007
Keeping the SWIG and PHP versions of MapScript sync'd has always been a challenge so it's possible
it didn't get added until 4.10.1 or later. At 4.10.0 you should have getShape which works the same
as getFeature (they wrap the same C code) but with getShape you must pass a tile index in addition
to the shape index. Usually it's just:
$shape = $layer->getShape(-1, $shpindex);
Steve
>>> Bill Thoen <bthoen at gisnet.com> 10/31/07 5:48 PM >>>
getFeature doesn't seem to be defined in version 4.10.0. When I try to
use it I get an error message that says it's undefined. Is this a recent
change, or should it be there?
Steve Lime wrote:
> getFeature is the method to use to retreive a feature from a layer. It is a layer method and
> exists for both PHP and the SWIG-based bindings. It replaces the getShape method which
> I created with stupid parameter orderings that made it impossible to not pass a tile index.
> I see that it is missing from the PHP/MapScript docs but is present in the Swig docs. I'll file
> a ticket on that one... There's already a note at the bottom of the page but it hasn't been
> noticed.
